I'm using Jira Work Management for my team. I'm trying to create reports using the reports tab. When I create a pie chart report, it seems to be pulling in all the subtasks along with the tasks. Is there any way to exclude the subtasks and have the report only pull the main tasks?
Thanks!
Hello @Denise Pickering
Yes, there is a way to do that.
Go to the Filters menu and select Advanced Issue Search.
Create a filter to select the issues you want from the Work Management project, excluding the subtasks.
Save the filter.
Then, in the first page of creating the Pie Chart, click on the link to Change Filter or Project and select the filter you saved.
You're welcome.
If your question has been addressed satisfactorily, please consider marking the Answer and Accepted to help other users find posts with validated solutions.
I followed your tips today and was able to build the exact report I was hoping to! Thanks again!
This article on our blog might be of great help for you: An effective dashboard for Service Desk and Customer Support teams in Jira Service Management
As you will see, you can build powerful reports in Jira or Confluence with our Great Gadgets app.
If you have questions, please don't hesitate to contact us at support@stonikbyte.com.
Danut M.
