Hi there!
First of all, let me say that this question was already asked in the link below, but has not been solved. The last reply was in December 2022.
I´ve been using the jira module that I believe is the official one and the worklogs function doesn't have a maxResults parameter.
I'm using jira==3.8.0
This is my code (with credentials and issue name removed):
from jira import JIRA
import jira
jira_options = {'server':server}
credentials = (email,token)
client = JIRA(options = jira_options,basic_auth = credentials)
issue = client.issue('myissue')
print(a.fields.worklog.total) # This line prints 9574 in my case.
# Can't use maxResults, I get:
# TypeError: worklogs() got an unexpected keyword argument 'maxResults'
work = self.client.worklogs(issue = issue) # Without maxResults it works.
print(len(work)) # This line prints 5000.
Thank you
The limit for max results is set on the server side, 5000 is actually very high! Generally it's 1000
You would need to set a loop to go through pages
This is the code we use:
# Run the JQL query and get the projects
proj_dict = {}
while True:
issues = jira.search_issues(jql_query, maxResults=max_results, startAt=start_at)
# If no issues are returned, we're done.
if not issues:
break
# Extract the key, project name, and project lead from the issues
for issue in issues:
project_key = issue.fields.project.key
project_name = issue.fields.project.name
if project_key not in proj_dict:
jra = jira.project(project_key)
proj_dict[project_key] = jra
else:
jra = proj_dict[project_key]
project_lead = jra.lead.displayName
project_data.append({
'project_key': project_key,
'project_name': project_name,
'project_lead': project_lead,
# Update startAt for the next batch of issues.
print(project_data[start_at:start_at+max_results])
start_at += max_results
print(len(project_data))
