Hello.
I am trying to recreate a sort of cascading list within scriptrunner. So basically creating two custom picker fields with the second one needed the value of the first one in order to show proper results. Eventually, both fields will be fed with an API request but for current step in developpment I am just using typical raw json responses.
The structure is as follows. For the first field.
def jsonBody_parent = """
"id": "1",
"name": "Hello"
"id": "2",
"name": "HYUNDAI"
"id": "3",
"name": "Toyota"
"id": "4",
"name": "Demo"
"id": "42",
"name": "The response to the universe"
The second level is as follows:
def jsonBody_child = """
"id": "1",
"name": "specialized",
"parent_name": "HYUNDAI",
"parent_id": "2"
"id": "2",
"name": "rockrider",
"parent_id": "2"
"id": "3",
"name": "toto",
"parent_name": "Toyota",
"parent_id": "3"
"id": "4",
"name": "tata",
"parent_name":"Demo",
"parent_id": "4"
So you can easily see that each first level entry has an id. The second level has a name and an id and a reference to the level one (I was testing both by id and name, for now I will filter by name but this does not really matter overall).
The ID of the Parent level is stored in customfield_19000 whereas the child is stored in customfield_19001
The issue I have is that I need to read the issue and gather the customfield_19000 value in order to further filter the second json before proposing it into the field.
importing com.atlassian.jira.issue.Issue
According to https://docs.adaptavist.com/sr4js/6.57.0/features/script-fields/built-in-script-fields/custom-picker.
When an Issue is provided, this is a "live" issue - it reflects changes made in the form during editing. This allows you to change possible selection values based on issue attributes, or indeed the current user roles and groups etc.
so for your code, you can just move codes related to:
// (this does not work)
def chantierId = issue.getCustomFieldValue(chantier_field)
to your search closure:
search = { String inputValue, Issue issue ->
// get the name of the chantier based on its id.
def chantierName = parsedResponse_chantier.find {
it.id == chantierId
}?.name
This works for me
Could you please share the full configuration of your custom picker fields?
I will review it and try to provide you with a solution.
Thank you and Kind regards,
Ram
Hi @Ram Kumar Aravindakshan _Adaptavist_ thanks for your help.
There is the code I use
import com.onresolve.scriptrunner.canned.jira.fields.model.PickerOption
import groovyx.net.http.ContentType
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.Method
import groovy.json.*
// Get the custom field chantier
def chantier_field = customFieldManager.getCustomFieldObject("customfield_10900")
// Get the name of the chantier corresponding to the chantierId - typical json response for the "chantiers" API
def jsonBody_chantier = """
"id": "1",
"name": "mon Chantier"
"id": "2",
"name": "HYUNDAI"
"id": "3",
"name": "Toyota"
"id": "4",
"name": "Demo"
"id": "42",
"name": "test id de la mort"
def parsedResponse_chantier = new JsonSlurper().parseText(jsonBody_chantier)
// typical response for the "velo" API
def jsonBody_velo = """
"id": "1",
"name": "speciallized",
"chantier": "HYUNDAI",
"chantier_id": "2"
"id": "2",
"chantier_id": "2"
"id": "3",
"name": "toto",
"chantier": "Toyota",
"chantier_id": "3"
"id": "4",
"name": "tata",
"chantier":"Demo",
"chantier_id": "4"
def parsedJson = new JsonSlurper().parseText(jsonBody_velo)
it.id == chantierId
}?.name
// Filter the velo list based on the selected chantier
def filteredList = parsedJson.findAll {
it.chantier == chantierName
filteredList.findAll {
it.name.toLowerCase().contains(inputValue.toLowerCase())
toOption = { Map<String, String> map, Closure<String> highlight ->
new PickerOption(
value: map.id,
label: map.name,
html: highlight(map.name, false),
icon: "https://www.svgrepo.com/show/493739/bike.svg"
getItemFromId = { String id ->
def selectedOption = parsedJson.find { it.id == id }
if (selectedOption) {
[id: selectedOption.id, name: selectedOption.name]
} else {
null
renderItemViewHtml = { Map chantier ->
"<p style='color:DodgerBlue;'>(chantierId = ${chantierId}, chantierName = ${chantierName}) Le vélo construit est : <b><u>${chantier.name}</u></b></p>"
renderItemTextOnlyValue = { Map chantier ->
chantier.name.toString()
