  • Community
  • Q&A
  • Jira
  • Questions
  • TFMLA project was successfully moved to FVAAGILE project, I am ready to close TFMLA PROJECT for some
Vara Prasad May 22, 2025
4 votes
Walter Buggenhout
Hi @Vara Prasad,
Boards and projects are different things. Deleting your TFMLA project will not delete your board.
What might be smart to do before you remove the project is check the filters of the boards you currently use (under board near the top right corner in your screenshot, you should be able to access the board configuration - look for the filter on the 'general', 'swimlanes' and 'quick filter' tabs) and make sure that they don't reference the old project anymore.
Other than that, you should be fine.
Hope this helps!
Walter Buggenhout
If you remove the TFMLA project from your Jira, your filter will reference that disappeared project. It will not break, but you will not be able to modify the filter itself until you remove the reference to the deleted project as well. So just a best practice recommendation to edit the filter and remove the project reference from your filter before you delete the project.
Vara Prasad May 27, 2025
Hi @Walter Buggenhout
Could you provide a step-by-step process description for unlinking the boards I want to keep from the project I want to delete?
