Technical problem with logging in to Jira ( Error Code : 500 )
bhimashankar_poddar
Hi All,
We’re running Jira Server version 9.4.14 within a Kubernetes Pod.
The Jira application itself is functioning correctly, and the login page loads as expected.
However, when I try to log in, I receive the following error:
"500: Sorry, we had technical problems during your last operation"
"Log referral number:<some code>"
Reference URL: https://<hostname>/login.jsp
We have two MySQL databases available for use:
- Database-1: Primary
- Database-2: Secondary
The login issue only occurs when configured 'dbconfig.xml' with the details of Database-1.
When configured with Database-2, the login works perfectly without any issues.
This suggests that the problem is related to Database-1 rather than Jira itself.
However, I need to identify the root cause of the problem and how to resolve it.
Any insights or suggestions would be greatly appreciated.
Thank you!!!
Jim Knepley - ReleaseTEAM
The log referral number will appear in the logs and you can get some additional details by searching for that number. You can download the logs as part of a support .zip or look at them in situ if you have access to the host.
You want the logs located in the Jira home directory, /var/atlassian, as opposed to the Jira install directory, /opt/atlassian. Those are default locations, your installation may be somewhere else.
