Two burndown chart for the same project and for the same workflow?
Vineet Kumar August 5, 2016
Hi All,
is it possible to create two different burndown charts which can retrieve the data from from the same project and the same workflow, the real issue is, one team want to include the whole workflow including the testing statuses but other team would like to have a burndown chart which should only query the issue from open to development (not to the end of the workflow) ??
Kian Stack Mumo Systems
Hello Vineet,
You can certainly do that! All you have to do is make a copy of the current board. On the copy, place "Development" as the final status (place it in the "Done" column) and remove the unnecessary steps. On the copy board, you can now run a burn down report that will consider "Developed" items as done.
Let me know if you have questions!
Kian
