Using JQL with SQL (from to) with SQL driver for Jira
Aquarius
Hi all,
I have installed SQL driver for JIRA and now I am able to perform advanced search using SQL.
Two questions:
  1. How can I use SQL queries in JIRA filters and combine them with JQL?
  2. How can I use JQL query in SQL driver for JIRA console to convert from JQL to SQL?
Aquarius.
Aquarius
Thank you Pablo smile
Do you by chance have an SQL query for issues added to the sprint after it started?
Thx,
Aquarius.
Pablo Beltran
January 20, 2017
Not yet, but I'm working to extend the SQL for JIRA - Data Analysis console to Agile, so it will possible to analyze Agil boards data out-of-the-box in a very powerful and friendly way to answer to question like this....
Aquarius
Thank you very much Pablo,
but when I run
issues in sql("
select i.key from issues i inner join issuecomments c on c.issueid=i.id where i.jql='reporter=currentUser()' group by i.key having count(*) >= 5
in issue navigator I get
Field 'issues' does not exist or you do not have permission to view it.
What is wrong?
Thanks in advance,
Aquarius.
Pablo Beltran
January 19, 2017
It is a typo: issues ( plural ) is not supported in JQL. Use please:
issue in ...
Pablo Beltran
January 19, 2017
Both questions seems to be related and are supported in SQL for JIRA Driver
Staring with your second question, the short answer is YES.
The ISSUES table has a special column named JQL. You have to use it as input to populate the ISSUES table with the data. Example, you might want to get your reported issues which have generated certain amount of debate/comments with threshold 5 (at least 5 comments)
select i.key as "Issue", count(*) as "Comments" from issues i inner join issuecomments c on c.issueid=i.id where i.jql='reporter=currentUser()' group by i.key having count(*) >= 5
copy and paste the query above in the SQL console and perform it to see the results.
In regard of your first question, any SQL for JIRA query can be converted back into a JQL by using the built-in sql predicate. Example:
issues in sql("
The JQL above can be saved as JIRA filter: "Top commented issues" and the use it as any other regular saved filter in JQL by using the filter keyword:
filter="Top commented issues"
atlassian, jira cloud certification, managing jira projects, jira project administration, jira cloud exam, atlassian certification, agile project management, jira workflows, jira permissions, jira training, jira cloud skills, atlassian learning
Become a Certified Jira Service Project Expert 🦸🏻‍♂️
Validate your expertise in managing Jira Service Projects for Cloud. Master configuration, optimize workflows, and manage users seamlessly. Earn global 🗺️ recognition and advance your career as a trusted Jira Service management expert.
Get Certified! ✍️
