  Hi @[deleted]
Welcome to the community!
Typical JSON syntax for creating or updating Jira ticket follows like:
"fields": {
"customfield_12345": {
"value": "Test data"
"description": "Testing for the REST API"
It should be PUT /rest/api/2/issue/{issueIdOrKey} call.
Note that all the fields you are setting/ sending via the JSON data should be present in the Edit screen of that issue type/ ticket.
Hope this helps.
Vamsi
  Hello Vamsi,
thank you so much for your answer!
Does this example go into the fields section or update?
Best Regards
Nauman
Hi @[deleted],
Can you try replacing the code in 'Felder' text box with this?
"fields": {
"summary": "Testing for the REST API"
This will update the summary of the ticket.
Vamsi
  Hey @Vamsi Kandala,
i have replaced the code in the box and sadly it throws the same error....
Best Regards
Nauman Qureshi
  I have also just noticed this:
perhaps this is why it keeps failing?
Hi @[deleted]
If you don't mind, can you send me screenshot of the url request you are making?
Vamsi
  Hi @Vamsi Kandala
sorry for the late reply.
I have just now noticed that the edit jira operation automatically adds the method: PUT.
And this obviously wont work because only:
