  • Community
  • Q&A
  • Jira
  • Questions
  • We'd like to use check lists to make sure all parts of a project are complete, what can you suggest?
Yuri Ivanov February 27, 2018
Hello, everyone!
We use JIRA Cloud and Confluence. Our usual approach is to create one or more stories when we have a project. In the story we create sub-tasks as necessary. In Confluence we record all work instructions.
At the end of a project we need to make sure that certain things were completed. This is not always exactly the same list of things, but more or less similar.
I would like to hear suggestions, or even direct instructions about how to implement a check list in our workflow. How not to forget to create one; how to automate creation of one (we are not JIRA gurus, so please describe things well).
Having a simple table in Confluence does not work because some of the items on a check list may trigger more actions, i.e. JIRAs.
Any suggestions, links to resources, tips?
Thank you!
Yuri
Gaston Valente
February 27, 2018
Yuri,
What about creating an issue of type "checklist" or "project end task" that gets created automatically when there're no unresolved issues.
This issue can have a subtask per action you need to do
Thank you very much, Gaston!
I simply did not know it could be done. Most likely this will solve our problem.
I will start looking at documentation, but if you can point me to a location, I will appreciate this a lot!!
Gaston Valente
February 27, 2018
Yuri,
You need some plugin to achieve this requirement, such as script runner.
You need to develop a listener or postfunction to check the status of the issues of the project, may be with a jql query and then create the issue
Gaston,
OK, I'm not sure about that. I'll see if we can find someone to help us. I don't know how to do that.
Thank you for all this information!
Gaston Valente
February 27, 2018
Are you using cloud or server ?
We use cloud.
Gaston Valente
March 5, 2018
Yuri Ivanov March 9, 2018
Thank you!
