I am trying to use the search issue portion of JIRA and I have found every single issue under my next gen project. The problem is, I don't know which field to add to my column view to see which issues have an assigned Epic and what that assigned epic is. I tried epic color, epic link, epic name, epic status, and epic/theme. None of them populate any valid information. I also tried parent.
Anyone have any ideas how I can view this information?
In the Board select Group By Epic and you will see the issues under each epic
