best way to recreate issues and subtasks to another project
Anca Cristescu
We have to create a new project definition for our development process, with new issue types, workflows....
We have to move/copy/clone the issues that are still in the old project to the new one, but they have a totally different structure:
Before:
task + subtask (and subtasks were differentiated by 'activity')
Now:
software problem + 5 types of subtasks
We try to use Clone+ for Jira to clone this issues... but it works ok for task, but not for our subtasks ...
Does anyone have any recommendations?
2 accepted
Clara Belin-Brosseau_Elements
October 22, 2024 edited
Hello @Anca Cristescu
And thank you @Marc - Devoteam for mentioning Elements Copy & Sync!
If I understand correctly, you’re trying to clone issues from a project to another one with different issue types, right?
In that case, I would recommend trying our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
You’ll be able to clone all the issues at once and map the different issue types from the old to the new project.
You can check the guide here.
The app is for free during 30 days (and it stays free under 10 users).
Marc - Devoteam
October 22, 2024
Hi @Anca Cristescu
This KB article should provide you with the content you need, this is based on Jira Automation
https://support.atlassian.com/automation/kb/writing-a-rule-that-clones-stories-and-their-sub-tasks-when-epic-is-cloned/
Or check the apps:
  • Deep Clone
  • Elements Copy & Sync
Anca Cristescu
Thank you both for your quick reply :-)
I'll test Elements Connect and see how this works for us. We are DC so we can't use Deep Clone.
My pleasure @Anca Cristescu
Be careful to use Elements Copy and Sync and not Elements Connect which is another of our apps but doesn't serve the same purpose ;)
Like Marc - Devoteam likes this
Anca Cristescu
Yes :)
We have Elements Connect also, and I wrote it by habit :)
Like 3 people like this
Ahah great ;)
SERVER
