define severity in post body
mahesh s.g.
April 16, 2020
I was trying to create a request using JIRA, which needs severity to be present
Example:
by post body is
"fields":{
"project":{
"key": "TEST"},
"summary": "TEST",
"description": "TEST",
"issuetype": {
"id": "101"
"components": [
"id": "35006"
output comes back as
{    "errorMessages": [],    "errors": {        "customfield_21681""Severity is required."    }}
I tried to add severity at multiple places wthin body it is not working
Matthias Gaiser [K15t]
My two fellow leaders are asking the right questions.
In order to help you a bit more, according to your error message, the severity in your Jira has the custom field id: customfield_21681
Now you need to know what type of field it is - is it a text or a select field or something else? That's influencing how you need to send it to Jira. This example assumes it's a select field:
"fields":{
"project":{
"key": "TEST"
"summary": "TEST",
"issuetype": {
"id": "101"
"components": [
{"id": "35006"}
"customfield_21681": {
"id": "ENTER ID OF THE OPTION"
If you need to know the id, you can get it via the createMeta endpoint. Also for more examples, you could check out the create Issue docs.
Matthias.
Stephen Crandell
April 16, 2020
What type of field is severity? Also, try adding it as customfield_##### instead of severity. Might be a typo in how it is listed in Jira.
Nic Brough -Adaptavist-
April 16, 2020
How have you tried to send a severity?
