error while creating an issue using Python script
Sumit Saini June 11, 2020
I am using below python script to create an issue.
new_issue = jira.create_issue(project='IN', summary ='test', description ='test1',  issuetype={'name': 'Bug'})
I am getting below error. Please help how to resolve it.
text: Squad is required.
	response headers = {'Server': 'AtlassianProxy/1.15.8.1', 'Cache-Control': 'no-cache, no-store, no-transform', 'Content-Type': 'application/json;charset=UTF-8', 'Strict-Transport-Security': 'max-age=315360000; includeSubDomains; preload', 'Date': 'Fri, 12 Jun 2020 06:06:05 GMT', 'ATL-TraceId': '09513638145b80a6', 'X-AREQUESTID': '65eda4a3-fe31-428a-b66c-e68a6e85bddc', 'X-AACCOUNTID': '5dee9b8004f61d0ec50f4123', 'X-XSS-Protection': '1; mode=block', 'Transfer-Encoding': 'chunked', 'Timing-Allow-Origin': '*', 'X-Content-Type-Options': 'nosniff', 'Micros-Issuer': 'micros/edge-authenticator', 'Connection': 'close', 'Expect-CT': 'report-uri="https://web-security-reports.services.atlassian.com/expect-ct-report/global-proxy", enforce, max-age=86400'}
	response text = {"errorMessages":[],"errors":{"customfield_10914":"Squad is required."}}
Derek Fields _RightStar_
You have a field named "Squad" on your Issue that is a required field. You will need to submit a value for that field in order to create the issue.
Sumit Saini June 12, 2020
Thank you for the reply. I added Squad, now I am getting below error.
text: Field 'Squad' cannot be set. It is not on the appropriate screen, or unknown.
 response headers = {'Server': 'AtlassianProxy/1.15.8.1', 'Cache-Control': 'no-cache, no-store, no-transform', 'Content-Type': 'application/json;charset=UTF-8', 'Strict-Transport-Security': 'max-age=315360000; includeSubDomains; preload', 'Date': 'Fri, 12 Jun 2020 16:20:12 GMT', 'ATL-TraceId': '1d4082ffea59cbab', 'X-AREQUESTID': 'a15c7be5-01a2-4af5-b37b-5206bd58270f', 'X-AACCOUNTID': '5dee9b8004f61d0ec50f4123', 'X-XSS-Protection': '1; mode=block', 'Transfer-Encoding': 'chunked', 'Timing-Allow-Origin': '*', 'X-Content-Type-Options': 'nosniff', 'Micros-Issuer': 'micros/edge-authenticator', 'Connection': 'close', 'Expect-CT': 'report-uri="https://web-security-reports.services.atlassian.com/expect-ct-report/global-proxy", enforce, max-age=86400'}
 response text = {"errorMessages":[],"errors":{"Squad":"Field 'Squad' cannot be set. It is not on the appropriate screen, or unknown."}}
My guess is that Squad is defined as required in the Field Configuration for the project. You need to add it to the Create screen for the Bug issue type
Ok thank you.
