I'd like to extract a sub string from last comment body by using smart values.
{{issue.comments.body.split("owner: ").last}}
For example:
Pls, make sure to ... as owner: A1234.
In this example A1234 as Owner by using
Kindly,
Gilad
The comments field is a list. Do you want this information from the last comment, or something else?
If the last one, please try this:
{{issue.comments.last.body.split("owner: ").last}}
Hi Bill,
I was able to change owner custom fields, but not reporter.
I saw in the community that we need to fetch customer.accountid.
My open issues:
1.Is this relevant for data center as well?
2.How do I now the actual account?
Kindly,
Gilad
I believe the smart value expression I provided should work with Server / Data Center, as it uses not specific Cloud features.
If you only have the user name and need the account id to set a field, there are not many options for Server / Data Center yet. I believe you would need to call the REST API with a web request to get the value. (Please note: the Lookup Issues action is being added for Server / Data Center automation...and once that is added it will be easier to use JQL to find the account id from an existing issue.)
