getting custom fields values between 2 issues in a same project without linked issue option
Cem Tuğrul April 2, 2024
Hello Forum,
Maybe this question is a very primitive BUT I could not realize and I do not know where to start. I have a issue type#1 and lets say the custom fields as A,B,C,D,E,F and then I have an another issue type#2 and the custom fields as REF_A, REF_B,REF_C
while creating issue on type#1 ; I need to get  the values for B,C from issue type#2
(issue type#1 A=REF_A issue type#2;)  then I need the values for B,C from REF_B and REF_C
Hope it is very clear:-)
Is there any solution and suggetion?
SAzaruddin.mp
Hi @Cem Tuğrul
It sounds like you want to populate the certain custom field values in issue type #1 with values from Issuetype #2 during the issue creation process. This can be achieved by using automation.
Identify trigger condition:
Determine when the automation should trigger. For example, you may want it to trigger when an issue of Type #1 is created.
Fetch values from issuetype #2:
Using built-in JQL functions to fetch the values of REF_B and REF_C from an issue of Type #2 (based on the value of REF_A)
Set Custom field values:
Set the values of custom fields B and C in the Issue Type #1 with the values obtained from Issue Type #2
Configure the automation rule:
Configure the automation rule in Jira to execute the above steps when an issue of Type #1 is created.
Here is example rule:
Trigger: Issue created (for Issue Type #1)
Condition: Issue matches criteria (Issue Type #1)
Action: Fetch REF_B and REF_C from Issue Type #2 where REF_A matches the value of custom field A in Issue Type #1.
Set values of custom fields B and C in Issue Type #1 with the fetched values of REF_B and REF_C.
Azaruddin
Cem Tuğrul April 3, 2024
Hello SAzaruddin_mp ,
Thank you very much for your answer.
Honestly , ı do not know how to setup a automation trigger. Is there any " Issue matches criteria" with "where" condition. Do you have an example?
