I want to create a quick filter for drop down of assignees and fix versions in the jira board
a quick filter for assignees as dropdown is already there by default, in case you are after having a dynamic quick filter that will show you both assignee and fix version in one dropdown i think you would need to search in the Marketplace for some solution for this.
Alternatively you can create a quick filter for fix version and then from board you need to apply assignee and fix version each separately and you shall get the tickets in common.
Hi @Madhuri Latha BhumiReddy , quick filters do not present drop downs. However, Assignees are presented by the Avatars at the top of the boards.
Hi @Madhuri Latha BhumiReddy please explain a bit more. Are you trying to create a quick filter? The drop down is the confusing part of you ask, what are you trying to do with a drop down?
