is there a way to copy issues from 1 project to another in jira cloud?
DI IELSI Carol June 12, 2018
is there a way to copy issues from 1 project to another? i have found how to clone an issue but then i don't see the move function which is supposed to exist and allow you to move the issue ot another project
Yogesh Mude
June 12, 2018
HI @DI IELSI Carol
Welcome to the community!
Yes, you can do this using Bulk change option.
First, you need to run the Jql like project = XXX and status =XXX or as you want then you can see the Bulk option at the right top corner on the screen.
Click on it and then you need to choose the move issue operation.
To move the issue from one project to another you should have the move issue permission for the project.
Here is the details documentation about this.
https://confluence.atlassian.com/adminjiraserver071/managing-global-permissions-802592439.html
