Hi - trying to use the x64 installer on a Centos server and I don't get to the point of any interaction with the installer but get an error message:
/tmp/atlassian-jira-6.3.12-x64.bin: line 466: /tmp/atlassian-jira-6.3.12-x64.bin.14178.dir/jre/bin/java: Permission denied
If I try to trap that path there is no java executable there. There is already a java 1.8 environment on the server though which it doesn't seem to find (if it's looking)...
What am I doing wrong?
Mark
Hello Mark!
When you install JIRA to run as standalone application (manually executed on the command line), it installs a standalone JRE in order not to depend from the one installed in your server.
Under UNIX systems, JIRA is automatically installed as a standalone application when you run the install script as an ordinary user instead of a root user.
Considering that you are running the installation script as an ordinary user, please check if this user you are executing the script with has both read and write permissions inside the reported folder. In order to do that, please run the following command on your terminal:
ls -l /tmp | grep atlassian-jira
Send us the output of this command.
-Joao
I am running as root root@vps40 [/tmp]# ls -l /tmp | grep atlassian-jira -rwxr-xr-x 1 root root 287251097 Dec 2 19:03 atlassian-jira-6.3.12-x64.bin* root@vps40 [/tmp]#
Can you make sure if your CentOS installation is 32-bit or 64-bit? In order to check that, run the following command on your terminal: uname -a Post here the output, please.
Hi @Mark Hayhurst,
I just ran into the same problem as well - seems like the problem was that the ordinary user didn't have enough permissions on the /tmp folder.
By moving the installer to the home directory, everything went perfectly fine!
Installing on Ubuntu 18.04 gave me the same problem. In my case it was caused by to little amount of swap file. Here is how I fixed it:
I copied my swap to a file. Advantige of this ist that its very easy to resize.
sudo swapoff -a
sudo dd if=/dev/zero of=/swapfile bs=1G count=8
if = input file
of = output file
bs = block size
count = multiplier of blocks
sudo mkswap /swapfile
sudo swapon /swapfile
grep SwapTotal /proc/meminfo
This solved my problem.
It's 64 bit
root@vps40 [/tmp]# ls -l atlassian-jira-6.3.12-x64.bin
root@vps40 [/tmp]# uname -a
Linux
root@vps40 [/tmp]#
And am trying to run the install as root so perms cannot be an issue...
Any other suggestions?
Mark
Also check that the installer is executable. chmod +x atlassian-jira-6.3.12-x64.bin
Mark,
Check if the user that you are running the installer has read / write permissions on the /tmp path. You will need an administrator user to properly install JIRA.
-- Pedro
