Hi All,
what should be the script for project role(like: Tester) condition on transition?
Means, only testers would be visible on particular transition.
I was trying this : isUserMemberOfRole('Testers') , but it's not working.
Thanks.
Hi @Pankaj You are trying to set up a condition, users which are in Tester project role only have permission to transition this issue, right ?
Instead of writing a scripted condition, you can this Condition Project role(s) condition [ScriptRunner] : Allows the transition if the current user is, or is not, a member of the specified project role(s).
yes , this condition is working , but I want to try through writing the script i.e , inline script.
@Pankaj I think you are trying to add Custom Scripted Condition, for this try below script :-
import com.atlassian.jira.security.roles.ProjectRoleManager
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def projectRoleManager = ComponentAccessor.getComponentOfType(com.atlassian.jira.security.roles.ProjectRoleManager)
def testerRole = projectRoleManager.getProjectRole("Tester")
def project = issue.getProjectObject()
def userInTesterRole = projectRoleManager.isUserInProjectRole(currentUser, testerRole, project)
log.warn userInTesterRole
passesCondition = userInTesterRole
yes its working , but could you please exlain the code step by step that will be very clear understanding for me or else we can able to write next condition or something by ourself.
Thank You very much.
@Pankaj Glad to hear I am able to help you out! Kindly accept the solution, if works for you as it helps other users looking for same solution.
Detailed Description :-
//get Current User/logged in User
//get project roles
//get Tester roles from Project Roles
//get Project Key
//check if user in Tester project role or not, it gives true or false value and value stores in variable userInTesterRole
//pass condition if userInTesterRole is true , fail if userInTesterRole is false
