Hello everyone,
I have a problem... I am importing a project from an external jira into my company's jira with a CSV file.
I filled in the "Map fields" part, but when I click on next I get this error message "Invalid project key, Project key must be no more than 10 characters long."
I would like to know how I could solve this problem? It's the first time I import a project on Jira.
thanks for your feedback :)
It's possible to increase the maximum size of the project key. But size 10 is recommended.
Go to Settings in General Configurations, click on Edit Settings and increase option size Maximum project key size.
Hello Djiga !
Thank you very much I just tested and it works !
Thank's a lot !
This is what it says it is.
Project keys on more recent Jra systems are limited to 10 characters.
You'll need to swap to a 10- scheme for your project keys.
Hello Nic !
thank you for your answer, I did the manipulation and it works thanks again!
Hello @Wakil BENAMOUR ! Welcome to the Atlassian Community!
What's the value of your Project key? Can you tell from the CSV file?
Hello Robert ! thank you :)
Here is the project key DAI1GRIDADVTG, and I have this error message :
"Invalid project key DAI1GRIDADVTG : Project key must be no more than 10 characters long."
And concerning the CVS file i don't know if i can modify it and put another project key? or the file might be corrupted? and if so how should i proceed?
sorry for these stupid questions but it's the very first time I do this manipulation :/
Thank You Robert !
What was the project key on the old instance?
Hello Robert
thank you i found the answer to my question everything works now :)
