Create Issue after Migrate from Jira Cloud to Jira Server
mschnieder
January 10, 2018
Hi everyone,
I have migrated from Jira Cloud to Jira Server and all data from the backup in Jira Server recorded. If I want to create a new issue now, I get the following error.
com.atlassian.jira.util.dbc.Assertions$NullArgumentException: ProjectRole should not be null!
at com.atlassian.jira.util.dbc.Assertions.notNull(Assertions.java:25) [jira-api-7.6.2.jar:?]
at com.atlassian.jira.security.roles.DefaultProjectRoleManager.getProjectRoleActors(DefaultProjectRoleManager.java:107) [classes/:?]
at com.atlassian.jira.notification.type.ProjectRoleSecurityAndNotificationType.getProjectRoleActors(ProjectRoleSecurityAndNotificationType.java:188) [classes/:?]
at com.atlassian.jira.notification.type.ProjectRoleSecurityAndNotificationType.hasPermission(ProjectRoleSecurityAndNotificationType.java:141) [classes/:?]
at com.atlassian.jira.permission.DefaultPermissionSchemeManager.lambda$hasSchemePermission$4(DefaultPermissionSchemeManager.java:443) [classes/:?]
at com.atlassian.jira.permission.DefaultPermissionSchemeManager.hasSchemePermission(DefaultPermissionSchemeManager.java:609) [classes/:?]
at com.atlassian.jira.permission.DefaultPermissionSchemeManager.hasSchemePermission(DefaultPermissionSchemeManager.java:443) [classes/:?]
at com.atlassian.jira.security.DefaultPermissionManager.doProjectPermissionCheck(DefaultPermissionManager.java:185) [classes/:?]
at com.atlassian.jira.security.DefaultPermissionManager.hasPermission(DefaultPermissionManager.java:107) [classes/:?]
at com.atlassian.jira.security.WorkflowBasedPermissionManager.hasPermission(WorkflowBasedPermissionManager.java:110) [classes/:?]
at com.atlassian.jira.security.DefaultPermissionManager.lambda$getProjectObjectsWithPermission$1(DefaultPermissionManager.java:292) [classes/:?]
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:652) [closure-compiler-v20151216.jar:?]
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143) [closure-compiler-v20151216.jar:?]
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138) [closure-compiler-v20151216.jar:?]
at com.google.common.collect.Iterators.addAll(Iterators.java:361) [closure-compiler-v20151216.jar:?]
at com.google.common.collect.Lists.newArrayList(Lists.java:160) [closure-compiler-v20151216.jar:?]
at com.google.common.collect.Lists.newArrayList(Lists.java:144) [closure-compiler-v20151216.jar:?]
at com.atlassian.jira.security.DefaultPermissionManager.getProjectObjectsWithPermission(DefaultPermissionManager.java:290) [classes/:?]
at com.atlassian.jira.security.DefaultPermissionManager.getProjectObjects(DefaultPermissionManager.java:261) [classes/:?]
Andre Lehmann
same for 7.8.0
Any Ideas?
mschnieder
January 10, 2018
7.6.3-x64
Nic Brough -Adaptavist-
January 10, 2018
What version of Server did you go to?
