separate create issue
Stanislaw Palak July 17, 2012
is possible in jira separate create issue for two grups in some project,
for example,
first grup can create only bug
second can create bug any other issue
r
July 17, 2012
as far as i know, the permission to create issues is inseparable. Which means, once you grant this permission, the user/group/role will be able to create any issue type assigned to the project in its issue type scheme.
Rad
