Add linked issue key to a comment using Automation for Jira
Jenifer Kuntz
I am creating a issue in our Dev project when a service desk goes through a transition. I want to add a comment to the service desk ticket letting them know which team it went to and the issue key.  The issues are linked. I am not having any luck adding the linked issue key into the comment.
I have tried all of the following -
{{issue.issuelinks.first.inwardIssue.key}}
{{issue.issuelinks.first.outwardIssue.key}}
{{issue.issuelinks.inwardIssue.key}}
my comment is added but where I have this nothing populates.
What do I need to use to add the linked issue key to the comment?
Thanks!
Jenifer
3 votes
Deleted user December 9, 2019
Hi Jenifer,
I'm Ilenice, from Automation for Jira support.
Thanks for your question :)
Well, if your DEV issue is created and linked to the SD through the same rule, you can use the {{createdIssue.key}} smart values to mention the DEV issue into a comment.
Please see this applied to an example rule:
I hope it helps!
Let me know if I can help you with anything else.
Ilenice
Florian
December 9, 2019
Try this in a global role:
Like # people like this
