Does the Sonar for Stash work with multi-module projects?
Luuk van den Broek
January 25, 2015
I can't get the issues to show in the diff view.
I have a single Git repo which hold several modules. the GAV is something like:
com.mycompany.project
com.mycompany.project.module1
com.mycompany.project.module1.submodule1
When running a sonar analysis from the repo root sonarqube assigns the following project keys:
com.mycompany.project:branch-name
com.mycompany.project:module1:branch-name
com.mycompany.project.module1:submodule1:branch-name
The add-on is configured with the project key : com.mycompany:project
However it fails to show information in the diff pane. I tracked the issue down to the call that Sonar for Stash makes to sonarqube:
The call Sonar for Stash makes:
https://mysonar.com/sonar/api/issues/search?resolved=false&severities=INFO,MINOR,MAJOR,CRITICAL,BLOCKER&components=com.mycompany:project:branchname:module1/submodule1/src/main/java/com/mycompany/path/to/file.java
The correct url for the call:
https://mysonar.com/sonar/api/issues/search?resolved=false&severities=INFO,MINOR,MAJOR,CRITICAL,BLOCKER&components=com.mycompany.project.module1:submodule1:branchname:src/main/java/com/mycompany/path/to/file.java
Have I misconfigured something or does the add-on simply not support multi-module GAV as parsed by sonarqube?
Mibex_Software
January 26, 2015
We've just released version 1.2.0 of Sonar for Stash yesterday which now includes multi-module support. Could you please upgrade and try again? You have to tick the checkbox "Multi-module support" in the repository settings of Sonar for Stash and specify the working sub-directory setting in the same way as you probably have done in Sonar for Bamboo.
Hope that helps.
Michael from Mibex Software
