Hi, I'm addressing BSP-7948 issue so I can inform you of the cause and fix in an effort to assist others. Please feel free to close this immediately.
h2. Fix:
JVM wrapper settings changes fix problem
h6. Approach
Setup 2 node system on pkdesk and pklaptop
Setup bogus forever job that runs cmd shell using infinite loop
Used stress tool to max server disk, cpu, memory - could not cause heart beat problem
Reviewed Logs and found pattern (see description). Agent attempts to restart JVM and complains of DLL problem on windows
* Fix DLL problem by running all win agents with x86 jdk
* Fix JVM restart problem by increasing time for jvm ping {code}wrapper.java.command=d: Java x86 jdk1.6.0_26 bin java.exe
wrapper.ping.timeout=900
wrapper.ping.interval=30
{code}
{quote}References
* https://answers.atlassian.com/questions/61674/remote-agent-crashing-when-being-farmed
* http://wrapper.tanukisoftware.com/doc/english/prop-ping-timeout.html
{quote}
Restart entire system
h2. Problem:
Agent builds stop and results lost after missing heartbeat. for months this appears to be server problem. Re-evaluate
* Determine if we can replicate the problem with micro environment under load
* Check agent logs looking for a pattern
h2. Situation:
{code}(78) 2013-02-12 11:12:22,785 INFO ActiveMQ Session Task DefaultErrorHandler
Recording error: Agent General Purpose Windows X64 (vmwbuild-03) went offline while building TRUNK-QUICKCOMPILEWINDOWS-2876.
The build results will not be saved. : TRUNK-QUICKCOMPILEWINDOWS
{code}
h3. Agent
{code}
ERROR | wrapper | 2013/02/12 11:08:54 | JVM appears hung: Timed out waiting for signal from JVM.
ERROR | wrapper | 2013/02/12 11:08:55 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:09:10 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:09:34 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:09:34 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:09:39 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:10:08 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:10:08 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:10:13 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:10:42 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:10:42 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:10:47 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:11:16 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:11:16 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:11:21 | Launching a JVM...
INFO | jvm 105 | 2013/02/12 11:11:31 | Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org
INFO | jvm 105 | 2013/02/12 11:11:31 | Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved.
INFO | jvm 105 | 2013/02/12 11:11:32 | WARNING - Unable to load the Wrapper's native library 'wrapper.dll'.
INFO | jvm 105 | 2013/02/12 11:11:32 | The file is located on the path at the following location but
INFO | jvm 105 | 2013/02/12 11:11:32 | could not be loaded:
INFO | jvm 105 | 2013/02/12 11:11:32 | d: bamboo-agent-home bin .. lib wrapper.dll
INFO | jvm 105 | 2013/02/12 11:11:32 | Please verify that the file is readable by the current user
INFO | jvm 105 | 2013/02/12 11:11:32 | and that the file has not been corrupted in any way.
INFO | jvm 105 | 2013/02/12 11:11:32 | One common cause of this problem is running a 32-bit version
INFO | jvm 105 | 2013/02/12 11:11:32 | of the Wrapper with a 64-bit version of Java, or vica versa.
INFO | jvm 105 | 2013/02/12 11:11:32 | This is a 64-bit JVM.
INFO | jvm 105 | 2013/02/12 11:11:32 | Reported cause:
INFO | jvm 105 | 2013/02/12 11:11:32 | D: bamboo-agent-home lib wrapper.dll: Can't find dependent libraries
INFO | jvm 105 | 2013/02/12 11:11:32 | System signals will not be handled correctly.
INFO | jvm 105 | 2013/02/12 11:11:41 | Agent bootstrap using baseUrl: http://vmbamboo-01:8085/bamb
{code}
Hello there,
When we restart the local JVM, this kind of problem can happen.
To avoid it, you can change the wrapper time, like this:
wrapper.ping.timeout=800
wrapper.ping.interval=35
Hope that helps.
