In my current organization, we use rich filters controller, 2d statistics and results view plug-ins for various time logging needs.
Now, we need to show user, issue key, comment, worklog comment and worklog hours.
Is there any way I can achieve it using rich filters.
Thanks in advance.
This is Dan from Rich Filters support.
It is currently not possible to display lists of worklog / worklog comments. You can filter based on worklogs, you can build statistics based on worklogs, but you cannot, for now, display flat lists of worklogs. Nevertheless, it is something we plan to address in the future.
I suggest you insert a Feature Suggestion on our support portal and if we manage to progress on this in the future, we will notify you.
Best regards,
Dan
