MS Project Conector: The AXIS engine could not find a target to invoke! Targetservice is theconnector
Tim Muir
May 21, 2012
trying to use the MS Project connector to send project to JIRA. Copied the jar file to WEB-INF directory but this did not resolve. Any ideas?
Onkar Ahire
December 19, 2012
f you have Atlassian JIRA 3.6 or greater:
  1. Download the JIRA Services for The Connector 2.0 from the website.
  2. Unzip the file com.ecliptictech.connector.jar and copy it to the WEB-INF/lib directory located under your JIRA installation root directory. This may vary from version to version on installation process.
  3. Enable the RPC extensions in JIRA
  4. Restart JIRA
If you are using Atlassian JIRA 5.0 or greater:
  1. Download the com.ecliptictech.connector-2.1-jira5.zip file
  2. Unzip the file com.ecliptictech.connector-2.1-jira5.jar and copy it to the installed-plugins directory located under your JIRA data directory.
  4. Restart JIRA
Tim Muir
January 7, 2013
That worked. Thank you!
