Can you please give the details to configure Incoming/outgoing mails in JIRA 5.2.10 version.Have following queries.
1.Any plugins needs to be downloaded from market place?if yes name of the plugin
2.Apart from SMTP server details any other details required from the developer side?
3.Configuration steps
Hi Mehala,
No plugins required.
Just follow the guides here.
Outgoing:
Incoming:
You should be all set.
Cheers
Bhushan
Hi Bhushan,
Thanks a lot.Followed the guides as you mentioned and it works now.
Mehala
