Problem in getting issue keys using Scriptrunner
Gupta Tulika
April 7, 2016
I am trying to enforce PullRequest policy enforcement using SCriptrunner plugin. I am trying to follow document https://scriptrunner.adaptavist.com/stash/latest/docs/event_handlers/#update-all-related-jira-issues-when-pull-request-opened. this line mentioned in the tutorial doesn't help me. Code breaks at this line.
def keys = jiraIssueService.getIssuesForPullRequest(repository.id, pullRequest.id)*.key
I tried to read documentation, but as per all odcs this is correct format.
Can you please suggest some alternative method or help me in fixing in same method?
adammarkham
April 8, 2016
Gupta Tulika
April 8, 2016
Yes, I have already replaced imports for Bitbucket. I get this error message , "Pull request creation was canceled.
  • A event handler failed to execute properly - contact an Administrator".  Please see my code below. I have put values which I am getting as comment. I am using Scriptrunner for other restrictions too, I have never faced this type of problem.
import com.atlassian.applinks.api.ApplicationLinkResponseHandler
import com.atlassian.plugin.PluginAccessor
import com.atlassian.sal.api.UrlMode
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.Response
import com.atlassian.bitbucket.event.pull.PullRequestOpenedEvent
import com.atlassian.bitbucket.integration.jira.JiraIssueService
import com.onresolve.scriptrunner.canned.bitbucket.util.BitbucketBaseScript
import com.onresolve.scriptrunner.runner.ScriptRunnerImpl
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
@BaseScript BitbucketBaseScript baseScript
//PullRequestOpenedEvent event = event
def pluginAccessor = ComponentLocator.getComponent(PluginAccessor.class)
def jiraIssueService = pluginAccessor.getEnabledPluginModule(ScriptRunnerImpl.PLUGIN_KEY + ":jiraIssueService").getModule() as JiraIssueService
//jiraIssueService=com.atlassian.bitbucket.internal.integration.jira.DefaultJiraIssueService@441068c9
def pullRequest = event.getPullRequest()
//0
def repository = pullRequest.fromRef.repository
//437
assert pullRequest
adammarkham
April 7, 2016
What errors are you seeing in the logs after the script runs?
If your running Bitbucket and not stash, you need to replace "stash" in the imports with "bitbucket", for example:
import com.onresolve.scriptrunner.canned.bitbucket.util.StashBaseScript
