Problem with behaviors' on entry validation
Paul December 4, 2018
Hi all,
I need to validate format for "My Example Field" during issue creation by a user.
User entry should consists of prefix (always "ABCD") and suffix (a number), e.g. ABCD12345.
The code below, obviously, doesn't work.
Problems:
1. If a user enter any string less than 9 characters, no validation happens; it has to be 9 or more.
2. Doesn't matter what a user enter for a prefix - no validation of prefix at all.
3. For string equal or more than 9 characters, only suffix is validated (characters from 5 to 9).
Code:
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
import com.opensymphony.workflow.InvalidInputException
String field = getFieldByName("My Example Field").getValue()
String prefix = field.substring(0, 4);
String suffix = field.substring(4, 9);
if (!prefix == "ABCD"){
getFieldByName("My Example Field").setError("Incorrect prefix: " + prefix)
else if (!suffix.isInteger()){
getFieldByName("My Example Field").setError("Incorrect suffix: " + suffix)
else {
getFieldByName("My Example Field").clearError()
Any ideas please?
Paul December 17, 2018
Bump.
It seems as an easy task but it looks like string format validation doesn't work in ScriptRunner?
