Hi All
I really don't know why this basic feature is not provided by JIRA. Seems more focus on selling third party apps. Tried searching alot for solution but solutions are flooded with to use particular third party app for connectivity with Power BI.
Finally found a way out from this curl snippest:
Using CURL
echo -n EMAIL:API_TOKEN | base64
curl -D- \
-X GET \
-H "Authorization: Basic TOKEN" \
-H "Content-Type: application/json" \
"https://DOMAIN.atlassian.net/rest/api/2/issue/ISSUE"
In power BI > Open Data > Web
I used https://www.base64encode.org/ to get base64 encode string from
myemail@company.com:API_Token
Add two headers as shown.
In Authorization enter Basic [Space] your base 64 token
Click ok and you will be connected successfully.
All steps are in this article https://www.linkedin.com/pulse/how-connect-power-bi-jira-using-rest-api-without-apps-vinod-kotiya-e5z7c/?trackingId=IIO74wGrYdL6NVabqaluPA%3D%3D
This is the only correct answer on the whole WWW. You are a lifesaver.
Hi @Vinod Kotiya
I am trying to connect JIRA to Power BI for reporting purpose. But I am unable to get the the basic authentication token, can you help me with this. How do I generate the API token and the connect to POWER PI.
I also want to restrict the data fields for a specific project too.
This is the closest and detailed explanation thread I found, but still since I am new in integration, any help would be appreciated,
Thank you
Your source m query should look something like this:
Source1 = Csv.Document(Web.Contents("https://YOUR_COMPANY.atlassian.net/sr/jira.issueviews:searchrequest-csv-all-fields/temp/SearchRequest.csv?jqlQuery=project+%3D+%22<PROJECT_SHORT_CODE_HERE>%22+ORDER+BY+created+DESC&atl_token=XXXXXX_lin&tempMax=1000&pager/start=0", [Headers=[Authorization="Basic <Base64_API_TOKEN_STRING>", #"Content-Type"="text/csv"]]),[Delimiter=",", Encoding=65001, QuoteStyle=QuoteStyle.Csv]),
#"Promoted Headers1" = Table.PromoteHeaders(Source1, [PromoteAllScalars=true]),
Again, I chose to export a CSV, but you may export a JSON by using the same URL you use to get the JSON file in your browser.
just a follow up question - is base64encode allowed in companies. Since we are integrating a third party tool. Data security is the main factor.
Just confirming in that case.
No idea really. You are just using it to generate a string and then you won't use it again. You can use any other base64 encoding tool I guess.
Ok. Thank you. Will check if this works.
Thanks again.
Hi @Rami Al Halabi
I have another question, lets assume if we do not perform a basic authentication and just want to get the Jira data to PowerBI, so I wondering that in that case what will be the approach.
Also do we have restriction on how many records we can pull and how to pull only the fields of one project.
Thanks for the help and your support.
Hello, in my experience, Basic Authentication did not work. That is why the steps above use an Anonymous connection with an Authorization header that has your generated API token. This is what is authenticating you.
I think there is a 1,000-record restriction on API calls. If you need more records you have to do multiple calls, but feel free to experiment with that. My Jira project does not have 1000 records yet.
Hi! How did you confirm your domain in the link used? and is your url pointing to a filter, or just the project space? thanks!
For the URL I used, I went to the Issues screen, I filtered the project I want to see > Export Issues Menu > Left-Click on Export CSV (all fields) > Copy Link Address.
Now that I think about it, I'm not using an API call in reality, so the 1000 items limit might or might not be in effect. You'll have to play around with it.
I added "&pager/start=0" to the end of the URL to tell it where to start in case it is returning more than 1000 records.
^^^^ This is finally what worked for me to get the filter results that I wanted into PowerBI. Thanks, Rami!
Hello! I know this forum is a bit old, but I can still say that it is the only one that worked for this direct connection from PowerBI to Jira.
But has anyone managed to pull only the columns (i.e., the fields) of the project they are looking for?
I made the connection as mentioned by @Vinod Kotiya and @Rami Al Halabi, but the return was more than 600 columns, because it came with fields from all projects.
Has anyone managed to return only the fields of the project that the JQL filter is on?
Hugs and thanks in advance.
Hi its quite simple. Just type "search?JQL=project=xyz&fields=duedate,assignee
This will return only limited columns.
I will write a detailed tutorial on this and publish here.
Great tip, thank you for taking time to share.
Unfortunately,
the /search? endpoint is now deprecated and the replacement /search/jql? expects nextPageToken instead of the Start keyword.
Have you considered updating the article with the latest API endpoint version?
Thank you.
JIRA's new issue search/filter view broke the ability to right-click 'Export CSV (all fields)' and 'Copy Link Address' to get the URL. I have created a support ticket with Atlassian and they created the following feature request:
https://jira.atlassian.com/browse/JRACLOUD-85425
I ask that everyone please vote, watch, and comment on the issue so that their devs can get more context from users and re-implement the feature. I also asked if Atlassian themselves could comment on this thread to give details on the breaking change. We'll see...
I have this same issue and it looks like the it has impacted existing reports that I had created with previous links. Now it's just exporting some sort of javascript you are right. Darn shame...
If you click the 3 horizontal dots (...) on the top right of the filter page, there should be an option for "Switch to the old issue search" or something like that. That's what I'm using to get that functionality back. Hope it sticks around!
I get the functionality back to get the link. But instead of getting a CSV format table when I import, it instead shows some weird HTML output that is not the data from the Filter table.
I have successfully connected Jira to Power BI.
When I fetch one issue from Jira that has a very long description, for some reason within Power BI, it shows multiple rows with different sections od the description value.
Is there any way to truncate description and ensure only one row is returned in Power BI so there is no duplication of rows?
Cheers.
Jimmy
Hello.
First of all, thanks and congratulations for this article. It was so helpful and, thanks to that, I could connect my report.
The only issue I am having is that I had to use a gateway to be able to do it, but actually it should not be needed, because Atlassian allows external connections.
When I try to connect without the gateway, I receive an authentication issue in the PowerBI webpage telling that The credentials provided for the Web source are invalid. I need some help, because with empy credentials in the gateway it works, but the same empty credentials in the configuration of the semantic model give error without the gateway.
Can someone answer the question above posed by Andrea?
"Hi, in this case I'm trying to do it exactly like you describe above, but I can't find the "Authorization" option."
You have to add headers manually by typing in Advance tab.
Hi, in this case I´n trying to do it exactly like you describe above, but I can't find the "Authorization" option.
Why you are looking in drop dowm. You have to add headers manually by typing it.
I am repeating the same steps but there is an error saying "We couldn't authenticate with the credentials provided. Please try again".
I did select Anonymous.
And also my URL is slightly different as it does not have .atlassian.net in it.
Thank you for the help.
