How to restore a JIRA Power bi connection deleted by mistake
Raymond Goulet
December 13, 2022
Is it possible to restore a JIRA power Bi connection deleted by mistake?
Callum Carlile _Automation Consultants_
Hi @Raymond Goulet
If you are using Power BI Connector for Jira, unfortunately I don't believe there is a place where a deleted connection can be retrieved. You could maybe create a support ticket with Atlassian to see if there's any way that the details can be recovered through the database
Maksym Kaprarenko _DOIT-BI_ December 13, 2022
Dear @Raymond Goulet
Nice to meet you.
Can you please specify which connector do you use?
Best regards,
Maksym
Raymond Goulet
December 13, 2022
Power BI Connector for Jira by Alpha Serve
Platinum Marketplace Partner for Jira Cloud,
I suppose you should open a ticket with their support. We have a competitive connector.
All the best,
Maksym
