In Jira Create issue in another project with Script Runner
Qi Jiang
I have few projects, A,B,C,D,E.
A is the high level project. B,C,D,E are low level project.
I need to create a postfunction on Project A, that will create a new issue on Project, based on a drop down list value in A.
For example:
drop-down list A: with value 1, 2, 3,4,5,6
If 1 was selected, after click save issue create button, clone save issue to project B, and link these two issues.
If 2 was selected, after click save issue create button, clone save issue to project C, and link these two issues.
If 3 was selected, after click save issue create button, clone save issue to project B, and link these two issues.
If 4 was selected, after click save issue create button, clone save issue to project D, and link these two issues.
If 5 was selected, after click save issue create button, clone save issue to project B, and link these two issues.
If 6 was selected, after click save issue create button, clone save issue to project E, and link these two issues.
Is there a way I can do that with script runner?
Any insight on the matter is highly appreaciated.
Kind regards
Qi Jiang
Mizan
If using post function Clones an issue and links , how to get new clone issue id and original issue id?
I did try issue.getid() , but no luck.
Mizan
October 15, 2017
The object for new cloned issue will be sourceIssue
I hope you are using getId() and not getid() .
Try to use as much logging as possible it will be helpful
Qi Jiang
@Mizan
After working around, I got code below, but looks like getId() is still null. code as below:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.workflow.TransitionOptions
MutableIssue issue = issue
def id=issue.getId()
def pid = sourceIssue.getId()
def creatorid = sourceIssue.getCreatorId()
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'ECUlist'}
issue.setCustomFieldValue(cf, sourceIssue.getCustomFieldValue(cf))
def authenticationContext = ComponentAccessor.getJiraAuthenticationContext()
//used for debug
log.debug "I will transit the subtask " + issue.key
log.debug "I will transit the subtask " + issue.id
log.debug "I will transit the subtask " + issue.getId()
//issue.summary = 'NEW Cloned Issue: ' + sourceIssue.summary
//issue.summary = "NEW Cloned Issue: " + "line 0 summary " + "sourceIssue.summary " + sourceIssue.summary
doAfterCreate = {
def cwdUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueService = ComponentAccessor.getIssueService()
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.setSkipScreenCheck(true)
issue.summary = "NEW Cloned Issue: " + "line 1 summary " + "sourceIssue.summary " + sourceIssue.summary
def issueLinkTypeManager = ComponentAccessor.getComponent(IssueLinkTypeManager)
doAfterCreate = {
def issueToLinkTo = issueManager.getIssueByCurrentKey(sourceIssue.getId().toString())
def duplicateLinkTypeName = "Duplicate"
// issue.summary = "NEW Cloned Issue: " + "line 2 summary" + "sourceIssue.summary " + sourceIssue.summary
// issue.summary = "NEW Cloned Issue: " + "line 3 summary" + "sourceIssue.summary " + sourceIssue.summary + "sourceIssue id: " + sourceIssue.getId()
// issue.summary = "NEW Cloned Issue: " + "line 4 summary" + "sourceIssue.summary " + sourceIssue.summary + "sourceIssue id: " + sourceIssue.getId() + sourceIssue.id
def duplicateLinkType = issueLinkTypeManager.getIssueLinkTypesByName(duplicateLinkTypeName)
if (!duplicateLinkType) {
log.warn ("Issue link type with name: ${duplicateLinkTypeName} does not exist")
else {
issue.summary = 'NEW Cloned Issue: ' + sourceIssue.summary + ' sourceIssue.id: ' + sourceIssue.id.toString() + ' Issue.id: ' + sourceIssue.getId().toString()+ ' Issue.id: ' + issue.getId().toString()+ ' Issue.id: ' + issue.id.toString()
// issueLinkManager.createIssueLink(issue.getId(), issueToLinkTo.id, duplicateLinkType[0].id, 1, currentUser)
issueLinkManager.createIssueLink(issue.getId(), sourceIssue.getId(), new Long(12000), null, authenticationContext.getLoggedInUser())
Mizan
October 16, 2017
Which post function are you using ?
Custom script or Clone issue ?
AND
This is not correct
issue id eg: 10001 , issue key eg: EX-109 .
Qi Jiang
@Mizan
ScriptRunner workflow function - Clones an issue and links (condition & additional actions apply).
Qi Jiang
@Mizan
Is there anyway we can setup a webex meeting?
Mizan
October 16, 2017
Sorry, that wont be possible.
Why you need any scripting if you are using clone issue function ?
Did you even try this and checked how it works ?
All you need to do is have multiple post functions for cloning the issue and linking. Each post function will have a condition which will check the drop down list value if it passes it will execute else return false.
Qi Jiang
@Mizan
Thanks for point out,
After I change togetKey(), still have same issue.
Mizan
October 12, 2017
You can do it via script runner. However, a cleaner and better way to do this is using the Bob swift add-on create on transition .
I cannot provide you a complete working script however, you can refer and try working on the below code snippet
def public CreateLinkedIssue(String ProjectName,String IssueType, String Summary, String Description){
// importing the required managers
def issueFactory = ComponentAccessor.getIssueFactory();
def issueManager = ComponentAccessor.getIssueManager();
def projectMgr = ComponentAccessor.getProjectManager();
def authenticationContext = ComponentAccessor.getJiraAuthenticationContext();
def issueMgr = ComponentAccessor.getIssueManager();
def issueLinkManager = ComponentAccessor.getIssueLinkManager();
// create new issue from factory
def issueObject = issueFactory.getIssue();
//set values
issueObject.setProjectObject(projectMgr.getProjectObjByName(ProjectName));
issueObject.setIssueTypeId("10000");
issueObject.setSummary("Child :"+issue.getSummary());
issueObject.setDescription(issue.getDescription());
issueObject.setPriority(issue.getPriority());
issueObject.setReporter(issue.getReporter());
//create actual issue
def child_issue= issueManager.createIssueObject(authenticationContext.getLoggedInUser(), issueObject)
Long lid=10003;
Long seq =1;
//link the issue
issueLinkManager.createIssueLink(issue.getId(),issueObject.getId(),lid,seq,issue.getAssignee());
Qi Jiang
Hi Mizan,
I have post function code as below, will you help me take a look?
import com.atlassian.jira.event.issue.AbstractIssueEventListener
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.user.util.UserUtil
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.util.ImportUtils
import com.atlassian.crowd.embedded.api.User;
import com.opensymphony.workflow.WorkflowContext
import org.apache.log4j.Category
import com.atlassian.jira.issue.customfields.CustomFieldType
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.issue.IssueFactory;
import com.atlassian.jira.user.util.UserManager
class TaskVersionListener extends AbstractIssueEventListener {
Category log = Category.getInstance(TaskVersionListener.class)
@Override
void workflowEvent(IssueEvent event) {
log.setLevel(org.apache.log4j.Level.DEBUG)
def issue = event.getIssue()
if ( issue.getIssueTypeId() == "XXXXX" ) { // The Issue Type to catch in the Listener
def projectName = "YYYYY" //Target project name
String currentUser = event.getUser().getName();
User currentUserObj = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
ComponentManager componentManager=ComponentManager.getInstance()
CustomFieldManager customFieldManager = componentManager.getCustomFieldManager()
log.debug "IF ISSUE IS TYPE XXXXX CLONE ISSUE TO PROJECT YYYYY WITH SAME FIELDS, ETC"
def newissue = issueFactory.getIssue()
newissue.setSummary (issue.summary)
newissue.setProject (projectMgr.getProjectByName(projectName))
newissue.setIssueTypeId("JJJJ") //The ID of the target Issue Type
newissue.description = issue.description
newissue.reporter = issue.getReporter()
//Set the Project Lead of the target project as assignee of the new ticket
def project = projectMgr.getProjectObjByName(projectName)
newissue.setAssigneeId(project.getLeadUserKey())
//Copy the fields that you want
def cf = null;
//ZZZZZ (list)
cf = customFieldManager.getCustomFieldObjects(issue).find {it.name == 'ZZZZZ'}
newissue.setCustomFieldValue(cf, issue.getCustomFieldValue(cf))
//YYYYYY (date) another way to obtain the custom field
cf = customFieldManager.getCustomFieldObject("customfield_NNNNN");
//XXXXXX (text, numeric, ...)
cf = customFieldManager.getCustomFieldObjects(issue).find {it.name == 'XXXXX'}
def params = ["issue":newissue]
def subTask = issueMgr.createIssue(currentUserObj, params)
def linkMgr = ComponentManager.getInstance().getIssueLinkManager()
linkMgr.createIssueLink (newissue.id, issue.id, Long.parseLong("ZZZZZ"),Long.valueOf(1), currentUserObj) //ZZZZZ is the id of the type of link
