Hi Team,
I need help
I have parent issues task under task i have links contains in issues in that link issues i have some calculated number field.
for ex in 1 task i have 60 and task 2 i have 90 both values need to calculate and average the fields and the average value need to display in parent.
xyz ----parent issues
Link conatins in
1 task child ---- number 60
2 task child ----- 90
60+90=150
average 150/2=75
the value 75 need to display in parent xyz field.
please help me how to write script for this
We need to know what app is providing the place for you to do the scripting.
We can assume you are using Jira as the application, as you're talking about issues, and in there I can tell you that you need to use a scripted field or listener to do the work, but Jira does not have any scripting functionality, so you need an app to add some, and before we can give you any scripts, we need to know which one you are going to use.
https://library.adaptavist.com/entity/calculate-the-sum-of-all-values-of-a-custom-field-in-linked-issues is a script that does most of what you want and is easy to add an "average" step to.
