Using project automation to run a custom script
Siavosh Kasravi
May 21, 2019
I like to run a task for each issue with project automation. It has every option except running custom script.
[edit]
Another way to say is that I want to run a custom script for each issue. What is the best way to do it?
Scott Harwood
May 21, 2019
Hi Siavosh,
Are you using Automation for Jira server, with script runner? If that is the case you can use a script runner action:
https://scriptrunner.adaptavist.com/5.4.47/jira/plugins/automation-for-jira.html
If your using cloud, or do not have script runner installed there is no scripting option. What are you trying to achieve, you maybe able to do this without a script?
Scott.
Siavosh Kasravi
May 22, 2019
Automation for Jira server. The problem is I can't find script runner's Run a script in Automation actions.
Scott Harwood
May 22, 2019
That is strange, can you please raise a support request and mention the version of Script Runner and Automation for Jira are you using?
https://codebarrel.atlassian.net/servicedesk/customer/portal/1
We will take a closer look.
Thanks.
Like Siavosh Kasravi likes this
