Script Runner Post Function Help (undeclared Variable)
Christopher Gronde
 I am trying to create a script runner custom script post function that will allow our tickets Due Dates to be automatically set depending upon the Priority they are given. (e.g. a BLOCKER level ticket has 1 day to be due)  I have piecemealed together the below scripts from other similar scripts I've found here in the forum.  The script appears to be failing at "MutableIssue mutableIssue = (mutableIssue) issue;" telling me that the variable "issue" is undeclared.  I'm not sure what exactly I have to do in order to make this work.  Can anyone take a look and see if you can help me fix my script?
import java.sql.Timestamp
// initiating the priority
def Blocker = 1;
def HIGH =2;
def MEDIUM = 3;
def LOW = 9;
def ROUTINE = 30;
// calendar which returns the date according to the priority defined
private GregorianCalendar getDate(double roll)
		GregorianCalendar cal = new GregorianCalendar();
		cal.setFirstDayofWeek(Calendar.MONDAY);
		cal.set(Calendar.HOUR_OF_DAY,0);
		cal.set(Calendar.MINUTE,0);
		cal.set(Calendar.SECOND,0);
		cal.set(Calendar.MILLISECOND,0);
		for (int x=0;x<roll;x++)
			cal.add(Calendar.DAY_OF_MONTH,1);
		return cal;
MutableIssue mutableIssue = (MutableIssue) issue;
def priorityObject = mutableIssue.getPriorityObject();
def priority = priorityObject.getName();
def setDueDate = mustableIssue.getDueDate();
//only set the dueDate if the date isn't already set
		GregorianCalendar cal;
		if(priority.equals("Blocker"))
			cal = getDate(BLOCKER);
	   else if(priority.equals("High"))
			cal = getDate(HIGH);
	   else if(priority.equals("Medium"))
			cal = getDate(MEDIUM);
	   else if(priority.equals("Low"))
			cal = getDate(LOW);
	   else if(priority.equals("Routine"))
			cal = getDate(ROUTINE);
		Timestamp dueDate = new Timestamp(cal.getTimeInMilliseconds());
		MutableIssue.getPriorityObject();
		MutalbeIssue.setDueDate(dueDate);
Vasiliy Zverev
October 19, 2016
Dear Kristofer, it seems that you do not have much experience in coding. Your script is too comples, since I simplified it:
private GregorianCalendar getDate( int roll)
    cal.setFirstDayOfWeek(Calendar.MONDAY);
    cal.add(Calendar.DAY_OF_MONTH,roll);
    return cal;
switch(issue.getPriorityObject().getName()){
    case "Blocker":     cal = getDate(1); break;
    case "High":        cal = getDate(2); break;
    case "Medium":      cal = getDate(3); break;
    case "Low":         cal = getDate(9); break;
    case "Routine":     cal = getDate(30); break;
issue.setDueDate(new Timestamp(cal.getTimeInMilliseconds()));
Also it is not clear about initial value for due date. Namely, does this script for issue creation step and due date = creation date?
Also I do not understand why do set due date to first day of a current week.
Vasiliy Zverev
October 19, 2016
Note, that variable issue already defined into a postfunction with class MutableIssue.
Christopher Gronde
You are correct I do not have much experience with Groovy script or coding.  I piecemealed this together from other similar scripts I found here in the forum.  This script will be a post function during the creation transition.  I'm assuming the initial due date should default to the date of creation and then add the amount of days required per Priority set.
Vasiliy Zverev
October 20, 2016
Here is a updated version of code. I did not test it, but it should work:
GregorianCalendar calendar = new GregorianCalendar();
    case "Blocker":     calendar.add(Calendar.DAY_OF_YEAR, 1); break;
    case "High":        calendar.add(Calendar.DAY_OF_YEAR, 2); break;
    case "Medium":      calendar.add(Calendar.DAY_OF_YEAR, 3); break;
    case "Low":         calendar.add(Calendar.DAY_OF_YEAR, 9); break;
    case "Routine":     calendar.add(Calendar.DAY_OF_YEAR,30); break;
issue.setDueDate( new Timestamp(calendar.getTimeInMillis()));
Vasiliy Zverev
October 20, 2016
It also could be helpful for you: https://answers.atlassian.com/questions/32982259
Christopher Gronde
now "def SetDueDate = mutableIssue.getDueDate();" is giving me a "variable 'mutable' is undeclared" error.  It also doesn't like the last line of your script.  It has three separate "cannot find matching method" errors.
Vasiliy Zverev
October 20, 2016
Where do you execute this script.
If into a postfunction, then variable issue have to be defined as MutableIssue.
If somewhere else you should get respective issue like this
//comment this line into postfunction
MutableIssue issue = ComponentAccessor.getIssueManager().getIssueObject("issue key")
Christopher Gronde
So I am running this a post function.  The script is running without errors but it doesn't seem to work.  Regardless of what I set the priority to if I search for the issue it shows todays date as the due date, and if I open the issue it doesn't even show me the due date on the details screen.
Vasiliy Zverev
October 20, 2016
All postfunction on issue update must be after issue create postfunction. See postfunction list.
Christopher Gronde
My post functions are as follows on the create transition:
  1. Creates the issue originally
  2. Re-index an issue to keep indexes in sync with database.
  3. Fire a Issue Created event that can be processed by the listeners.
  4. Script Runner post function script
Vasiliy Zverev
October 21, 2016
I forgot that on create issue transition there is no store step. Here is updated version of code
import com.atlassian.jira.event.type.EventDispatchOption
ComponentAccessor.getIssueManager().updateIssue(
        ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser()
        , issue
        , EventDispatchOption.ISSUE_UPDATED
        , false
Christopher Gronde
So now the due date is finally showing up in the details of the ticket, but it's still not updating the date based on priority.  It's only marking it with today's date.
Christopher Gronde
The calendar doesn't seem to be storing the additional days when you call the calendar.getTimeInMillis()....if I add + "some number" after that call I can manually add milliseconds, but it isn't calling the switch
Vasiliy Zverev
October 21, 2016
I would recommend you to test script into script console.
Make sure that priority names are correct.
Christopher Gronde
Tested the script in the console and got the below error:
java.lang.NullPointerException: Cannot invoke method getPriorityObject() on null object
     at Script288.run(Script288.groovy:22)
Vasiliy Zverev
October 24, 2016
Into script console you need to initilise issue variable, see comments:
//Comment it into a postfunction
MutableIssue issue = ComponentAccessor.getIssueManager().getIssueObject("issueKey")
        , issue
        , false
Christopher Gronde
yes I ran that version in the console...that's how I got that error.
Christopher Gronde
I did also verify that the names of the priorities were correct including capitalization.
Vasiliy Zverev
October 25, 2016
Did you changed "issueKey" to actual key of a tested issue?
Christopher Gronde
When I change "issuekey" to ES-9634 the result at the bottom says "ES-9634" and the log tab says null
Christopher Gronde
When I searched for the issue again NOW it shows the newly updated date...so it WORKS in the console!
Christopher Gronde
So why doesn't it work as a post function?
Vasiliy Zverev
October 25, 2016
Into post-function it is requred to comment line with variable "issue"
Christopher Gronde
Should I run it as a Listener instead of a post function?
Vasiliy Zverev
October 25, 2016
Listener is better if you have to do something on different workflow/transition.
So, if you need this only for this workflow then you should use postfunction, otherwise - make a listener.
Christopher Gronde
I do comment out that line when I add it to the post function.  Still only updates the due date with today's date but then when I run it without that line commented in the console it will update the date to what I want it to be.
Vasiliy Zverev
October 25, 2016
Could you provide list of post-functions?
Christopher Gronde
  1. Create the issue originally
  3. Fire an Issue created event that can be processed by the listeners
(I have tried the script as step 3 and 4 with same result)
Vasiliy Zverev
October 25, 2016
Try to investigate atlassian-jira.log on JIRA server. Maybe some errors occur on transition.
Christopher Gronde
There are no errors in the log after creating a new ticket.
Vasiliy Zverev
October 26, 2016
Try place "Script Runner post function script" rigth after "Create the issue originally"
Christopher Gronde
same outcome (Today's Date), no errors.
Vasiliy Zverev
October 26, 2016
Lets try update description also:
issue.setDescription(issue.getDescription() + " they killed Han Solo, bustards")
        , issue
        , false
Christopher Gronde
Ok so I don't know how or why, but it not only added the description you set, but it also set the correct due date.  I then commented out the setDescription and it still works with the due date...did you change anything else?
Christopher Gronde
I also have the "MutableIssue issue =" commented out.
Vasiliy Zverev
October 26, 2016
No, but it works, it is good.
Christopher Gronde
This currently works in 6.4.4, am I going to have to change anything when we upgrade to 7.1.2
Vasiliy Zverev
November 1, 2016
Unfortunately we use JIRA 6.4since I can not test it for JIRA 7. Anyway, ask here for help if troubles appear.
Christopher Gronde
Is there and if/then statement I can add to the script so that it does NOT update if someone manually sets the due date.  To only update if due date is blank?
Vasiliy Zverev
November 3, 2016
Here it is: if(issue.getDueDate = null){
Christopher Gronde
thanks!  That kind of what I figured it would look like.  Thanks for all your help!
Faiza Kazmi May 8, 2019
how can i get issue key dynamically while putting on a transition in script runner post function
@Vasiliy Zverev please find attached code its not picking up issue key when i create an issue and apply the code in post function
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.event.issue.field.CustomFieldUpdatedEvent;
import com.atlassian.jira.issue.Issue;
//def projectComponentManager = ComponentAccessor.getProjectComponentManager()
def issue = ComponentAccessor.getIssueManager().getIssueByCurrentKey("");
def userUtil = ComponentAccessor.getUserUtil()
def cField = customFieldManager.getCustomFieldObject("customfield_10604")
def cFieldValue = issue.getCustomFieldValue(cField).toString()
userUtil.createUserNoNotification(cFieldValue,"",cFieldValue,cFieldValue)
def groupManager = ComponentAccessor.getGroupManager()
def user = userUtil.getUserByName(cFieldValue)
def group = groupManager.getGroup("BM")
groupManager.addUserToGroup(user,group)
Vasiliy Zverev
May 13, 2019
This line returns issue with specified issue key. It is requared to test script into Script console.
Into postfunction there is a predefined variable named issue which represents current issue. You should comment this line into postfunction,
