problem with import in jython postfunction script Jira
MUNTEANU CATALINTIBERIU November 18, 2014
Hi
I'm trying to migrate from JIRA 4.2.4 to JIRA 6.2.7
Among other problems that I encountered, now it came out another
I have many post function with jython script
I also use JIRA rpc in those scripts
In JIRA 6 rpc plugin is bundled (as difference from 4.2.4 where i had to put it in /lib)
Now my jython script gives me error on import:
/secure/CreateIssueDetails.jspa [jira.plugin.workflow.JythonValidator] Unrecognized exception while executing Jyphon script: null
Traceback (most recent call last):
  File "<string>", line 2, in <module>
ImportError: No module named rpc
    at org.python.core.Py.ImportError(Py.java:290)
at line : "from com.atlassian.jira.rpc.soap import JiraSoapService"
The plugin shows that is enabled in JIRA
Please Help me to resolve that import so that my scripts continue to work
Thank you
MCTibi
Alex Shchagin
November 20, 2014
Hi!
As I said, this is an OSGi issue. This is not a JSS bug and thus can not be fixed.
To get a Class a class (e.g. DB driver) from a system classloader:
from com.atlassian.jira.component import ComponentAccessor
drv = ComponentAccessor.getClassLoader().loadClass("org.postgresql.Driver").newInstance()
print drv
To get a class from another OSGi plugin - actually any v2 JIRA plugin - you need to have an access to that plugin classloader. As I said, I do not have a solution for that out of hand.
Alex
MUNTEANU CATALINTIBERIU November 20, 2014
thanks Alex At least I now know that I have to look in other directions.. you saved me some time thanks again MCTibi
MUNTEANU CATALINTIBERIU November 21, 2014
Hi again.. one more little thing.. It now gives me java.sql.SQLException: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@xxx:1540:xxx the code is: from com.atlassian.jira.component import ComponentAccessor from java.sql import DriverManager drv = ComponentAccessor.getClassLoader().loadClass("oracle.jdbc.OracleDriver").newInstance() url = "jdbc:oracle:thin:@xxx:1540:xxx" db_user = "user" password = "pass" dbconn = DriverManager.getConnection(url, db_user, password) please help thanks MCTibi
In additional to the problem above I have also a: Error creating issue: root cause: Traceback (most recent call last): File "<string>", line 91, in <module> at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:772) at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73) at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.ClassNotFoundException: java.lang.ClassNotFoundException: oracle.jdbc.driver.OracleDriver Can you tell me how can I make it work? In there any possibility to acces these external classes from Jython? I use jss-2.3.0 in jira 6.2.7 Please help.. we're stuck with Jira migration because of that Thank you MCTibi
