script errors when using jira suite utilities IE 9
Dan Flint
October 10, 2012
I have experienced issues when trying to use tempo and selecting dates from the calendar pop up when creating issues. After disabling jira suite utilities both issues dissapeared. The errors reported when using tempo are shown below (note the first two are reported on the other issue).
Line: 1
Error: Unable to get value of the property 'split': object is null or undefined
Line: 1
Error: 'Calendar' is undefined
Line: 1
Error: Unable to get value of the property 'Model': object is null or undefined
Line: 75
Error: Unable to set value of the property 'dropdown': object is null or undefined
Line: 233
Error: Unable to set value of the property 'navigation': object is null or undefined
I really like the functionality that is found within jira suite utilities but unfortunatly can not use it with the issues it appears to be causing.
Thanks in advance
Dan
Dan Flint
October 14, 2012
User error - Was using the latest version of the plugin on an older version of jira.
