validating multi check box custom field using script runner plugin
Akhil Kanaskar March 18, 2014
I have a multi check box custom field 'DOD' , which has options/items as start,stop,resolve.
Now what i want to implement is whenever a user tries to close a issue he should have atleast ticked start in custom field, if he has done so he will be able to close issue else he wont.
For this i am using script runner plugin and implemented a workflow validator on close issue as 'simple scripted validator' .
The condition in this simple scripted validator i have put is show below
cfValues[DOD] == 'start'
However this doesnt seems to work and although if the user ticks the 'start' in customfiled DOD he is not able to close issue.
Can someone please help me?
Akhil
RambanamP
March 18, 2014
cfValues['DOD']*.value.contains("start")
try something like above code
Thanks .... that worked
But if i want to check all options then below command doesnt work ...Any idea
cfValues['DOD']*.value.contains("start","stop","resolve")
JamieA
March 19, 2014
cfValues['DOD']*.value in ['start', 'stop', 'resolve']
Akhil Kanaskar March 19, 2014
This also doesnt work for me .... i still see errors in log
2014-03-20 10:24:19,074 http-bio-8080-exec-19 ERROR admin 624x502x1 kffx3j 127.0.0.1 /secure/CommentAssignIssue.jspa [atlassian.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 2 from workflow 10300 on issue 'COR-1'
[InvalidInputException: [Error map: [{}]] [Error list: [[error 101]]]
JamieA
March 20, 2014
In condition tester run:
cfValues['DOD'].value*.value.contains("start")
and provide the output here. I didn't really read your question properly - you just want to ensure that at least "start" is checked? If so I think the above should do it.
Akhil Kanaskar March 20, 2014
Hi Jamie,
I want to check that all three options(start,stop,resolve) of the DOD custom field should be checked, and only if all 3 options are present then only the transition would happen else it should fail
Kathryn Allison
How do I say does not contain?
JamieA
December 20, 2014
! cfValues['DOD'].value*.value.contains("start")
Akhil Kanaskar March 24, 2014
see attached screenshot below for TICK-5 in which i have checked all 3 options, so as per my understanding the result should evaluate to true but thats not the case.
Hi Jamie,
Below is the output of cfValues['DOD']*.value in ['start', 'stop', 'resolve'] in condition tester.
Hi jamie,
Below is the output from condition tester on an issue
javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: value for class: Script1
