×Hi,
I updated sourcetree on both of my machines (computer and notebook) and now I can't fetch, push or pull to/from all of my remote repositories, located on two different servers.
If I click the git bash command line and try to access the remotes all things are working like they should.
So the connection to the remote is there and functionable. Only sourcetree is not working.
What can I investigate to find the error?
thx,
Jesta
Hi
OK it looks like you are using SSH urls that require username/password credentials rather than keys. There is a bug in the PuTTY/PLink upgrade in 2.4.7.0. Please follow https://jira.atlassian.com/browse/SRCTREEWIN-8264
so, now i tried reinstalling sourcetree, running as admin, but still got the error.
git bash is working fine. creating new repos and "trading" them between my machines work, ssh data is the same as sourcetree is showing.
the repositories are on two servers, linked over ssh.
error:
Hi
What type of remote URLs are you using to connect to the host servers, HTTPS/Git/SSH ?
What error do you see?
