Finish it... How do you tell what System Git is using? Also, is it through Windows or MinGW?
Gary Creech
This question is in reference to Atlassian Documentation: Using Embedded Git or System Git in SourceTree
Ask your question here...
Gary Creech
Which system is it using ... MinGW (terminal shell) or Windows CMD? ... and what context do you type in git --version?  In the Terminal command line??
I have proved to myself that the Custom Commands in SourceTree uses the Windows CMD environment (on my Windows version).
Thanks for the quick reply!
Update:  Did this from both a CMD window and a terminal window .... got the same answer ...
git version 2.8.3.windows.1  .... (but that still does not tell me which git.exe is being executed in SourceTree ... MinGW or Windows CMD).
Jonas Andersson
January 11, 2017
git --version
