I am having a problem with SourceTree, where I start off with only a master branch, and then I enable git flow with defaults, which only creates a develop branch.
The issue here is that when I click on Git Flow button, it gives me the option to finish develop feature, which merges develop with itself, instead of providing a menu to create features and others. The Git flow is treating the develop and master as features instead of branches.
Am I doing something wrong in the Git Flow setup?
I have the same issue in Windows (Sourcetree version 3.3.4), also when i follow the flow with "Other action" > "Start new feature" and create a feature, it is now showing as a branch and not like in previous versions (inside a "folder" with the name "feature").
The workaround for this is manage my branches with responsibility with the concept of git-flow in mind, i mean, all in a manual way.
I recall opening the config file in the .git folder at the root directory of my repository and noticing that the section [gitflow "prefix"] was not initialised. I had to manually repair these as:
[gitflow "branch"]
master = master
develop = develop
[gitflow "prefix"]
feature = feature/
release = release/
hotfix = hotfix/
support = support/
versiontag =
