I understand for command line, there are various options just as -p to push the commits when finishing a hotfix. However, hotfix in sourceTree does not have that option. Is there a way to include that?
The windows verision only has Delete branch and Force Delete. Not sure the different between the two though..
Oops, the setting was there but the visibility was wrong so it wasn't showing up for hotfixes or releases. Will be fixed in 0.9.4.
Hi Carolyn,
When finishing a hotfix you can push the changes by selecting "Push changes to remote" as this is what the "-p" option does on finishing a hotfix in git flow. For example, the Mac version has the following:
The Windows version has something very similar, too.
Hope that helps
