Hey, I have the latest version of sourcetree and on my main monitor (120hz), the cursor lags noticeably, while it doesn't do that on my second monitor (75hz). I tried running it as an administrator or with compatibility settings (for win 7/8) but no luck. CPU usage is not an issue, and the repository I have is a brand new one (even with the repo closed I still have cursor lag).
Any idea what could fix this? Is there any hardware acceleration available or something?
Think I found the solution. Go to nvidia control panel, manage 3D Settings, add the program to the list of programs (In Program Settings), then select "Fixed refresh" for Monitor Technology.
Sadly this actually bring in another issue, that shadowplay latches onto the program now and messes up the window with frame rate display limiting my ability to record the main screen.
I'll have to switch to kraken sadly, that one is more stable
We have seen odd issues to do with graphics cards drivers that have been fixed after updating those drivers, could that be applicable here?
I have a fairly recent Nvidia driver. Could be.
Last night I also tried adding sourceTreee in the list of programs that have their 3d settings managed in the Nvidia Control pannel. It fixed the issue, but it was only temporary. I will play around with that today again to see if I can get it stable
