Installation problem localhost:34106
madhavikadam
January 17, 2019
We are facing a problem when we are installing. When we are in Registration stage and clicking Bitbucket, we are routed to this URL
https://bitbucket.org/site/oauth2/authorize?response_type=code&client_id=HJdmKXV87DsmC9zSWB&state=authenticated&redirect_uri=http://localhost:34106/
Now after authenticating via atlassian site and gmail, we are routed back to http://localhost:34106/?state=authenticated&code=eVTfGVpH3jjzKSPMju
with status Authentication successful, pfa screenshotatlassian sourcetree.PNG
Post this also the Next button of Registration window is still inactive.
Please help us in this regard as soon as possible, as are work is stalling because of this.
Jim Scott
May 29, 2020
For those having this problem, take the URL from the browser that popped up and open firefox and paste the URL in and change HTTPS to HTTP and execute and it will work. It appears that that Chrome and Edge have an issue with the SSL configuration and for whatever reason do not allow you to use HTTP and instead rewrite the localhost request to https. In firefox it leaves it alone and uses whatever you provided.
the RAD coder
October 10, 2020
This worked for me fixing similar issue trying to refresh BitBucket OAuth token. Thanks for the tip @Jim Scott !
Like Jim Scott likes this
caedmonm
January 8, 2025
Or, if you want to continue using Chrome:
  1. Stop anything you have running on localhost (ie Node, etc)
  2. go here: chrome://net-internals/#hsts
  3. Delete localhost from the HSTS policy
  4. Try to authenticate again
Fuzzball Coding
May 4, 2022
Clearing the Bitbucket and Atlassian cookies from the browser that the auth flow tries to open seems to have worked for me.
mcvendrell
August 16, 2020
Incredible that this is still happening by Aug 2020...
Finally, what I did is:
  1. Install old version 2.
  2. Configure it.
  3. Install now version 3.3.9.
Now is working.
Edward Wilson
April 29, 2021
Incredible that this is still happening by Apr 2021
Like mcvendrell likes this
pokey00000000
August 26, 2021
Incredible that this is still happening by Aug 2021...
Nishith Venkata
October 5, 2021
Hi @Edward Wilson , I was facing the same issue. I followed the below tutorial and it helped. Hope it helps you as well
Link: https://www.youtube.com/watch?v=eVrsMDAvyvI&ab_channel=Britec09
TheCloudGroup
March 9, 2022
Incredible that this is still happening by March 2022
Like # people like this
Dobromir Popov
March 21, 2022
Incredible indeed.
I lost the whole day today trying to pull the latest code.
HTTPS and SSH are both not working !!!
And 2FA is not even enabled for my account or for the repository. And yet, is is popping up AND NOT WORKING. Disaster
Fuzzball Coding
May 4, 2022
Confirmed still happening May 2022
Like Miroslav Stefan likes this
Nguyen Trung Tin
June 23, 2023
oh yeah 2023 still got this problem
Like Florian de Groot likes this
Vitali Kachan
June 26, 2023
Yes, still happens
Florian de Groot
June 14, 2024
oh yeah 2024 still got this problem (Made a copy from Nguyen Trung Tin, changed the year)
franklnielsen
March 17, 2020
Also tried install 3.3.8 on a new fresh machine, but without success. I choose "Bitbucket" account, and after browser pops up with username/password in redirects to: http://localhost:34106/?state=.... but nothing is listening on that port?
The sourcetree.log says:
2020-03-17T11:18:50: LogHost: Initializing to normal mode
2020-03-17T11:18:50: LogHost: Failed to handle Squirrel events: System.MissingMethodException: Method not found: 'Void Splat.IFullLogger.Info(System.String, !!0, !!1)'.
at Squirrel.UpdateManager.ApplyReleasesImpl.CreateShortcutsForExecutable(String exeName, ShortcutLocation locations, Boolean updateOnly, String programArguments, String icon)
at Squirrel.EasyModeMixin.CreateShortcutForThisExe(IUpdateManager This)
at Sourcetree.Installer.Squirrel.SquirrelApplicationUpdater.<>c__DisplayClass13_0.<EnsureSquirrelExecutionStubIsCopied>b__0(Version v)
at Squirrel.SquirrelAwareApp.HandleEvents(Action`1 onInitialInstall, Action`1 onAppUpdate, Action`1 onAppObsoleted, Action`1 onAppUninstall, Action onFirstRun, String[] arguments) - System.MissingMethodException: Method not found: 'Void Splat.IFullLogger.Info(System.String, !!0, !!1)'.
ERROR [2020-03-17 11:18:51,622] [1] [SourceTree.Analytics.Submission.Gas.GasAnalyticsSubmissionService] [Log] - Hi There!
ERROR [2020-03-17 11:18:52,239] [19] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
System.IO.FileLoadException: Could not load file or assembly 'TimeZoneConverter, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'TimeZoneConverter, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null'
at Atlassian.AnalyticsService.Client.Converters.IanaTimezoneConverter.WriteJson(JsonWriter writer, Object value, JsonSerializer serializer)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable(JsonWriter writer, JsonConverter converter, Object value, JsonContract contract, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject(JsonWriter writer, Object value, JsonObjectContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType)
at Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType)
at Newtonsoft.Json.JsonConvert.SerializeObjectInternal(Object value, Type type, JsonSerializer jsonSerializer)
at Sourcetree.Analytics.Emau.EMauSubmissionService.<SubmitBatch>d__61.MoveNext()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
ERROR [2020-03-17 11:18:52,318] [1] [SourceTree.UI.OnboardingManager] [Log] - Unable to submit Finished Registration Analytics
System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The request was aborted: Could not create SSL/TLS secure channel.
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
--- End of inner exception stack trace ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at Refit.RequestBuilderImplementation`1.<>c__DisplayClass13_0`1.<<BuildCancellableTaskFuncForMethod>b__0>d.MoveNext()
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at SourceTree.Mau.Submission.Gas.GasMauSubmissionService.Submit(GasEvent userActivityEvent)
at SourceTree.Mau.Submission.Gas.GasMauSubmissionService.ForceSubmission()
at SourceTree.Analytics.AnalyticsDataManager.ForceSubmission()
at SourceTree.UI.OnboardingManager.SubmitStartedRegistrationAnalytics()
---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The request was aborted: Could not create SSL/TLS secure channel.
at Refit.RequestBuilderImplementation`1.<>c__DisplayClass13_0`1.<<BuildCancellableTaskFuncForMethod>b__0>d.MoveNext()<---
ERROR [2020-03-17 11:18:55,381] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
Mike_Scharnow
February 18, 2020
SourceTree 2.6.10 which has its own window for registration worked for me. the variants where a browser is opened (3.1.3, 3.3.8) had the same problem: connection refused all the time with chrome, IE and FF
Mike_Scharnow
February 18, 2020
btw: after registration using 2.6.10 it was possible to update the to the newest version automatically
Like Val Quintero likes this
franklnielsen
March 17, 2020
thanks, i got it installed this way.
Val Quintero
April 15, 2020
I was having this issue when trying to install SourceTree 3.3.8 on a laptop for the first time.
I then tried installing 2.6.10 as suggested and successfully installed.  But now, I try to run the v3.3.8 but it cannot update due to the same registration issue.
How can I update to the latest version automatically?
durova January 24, 2020
Have the same problem, in WIndows 7, with Firefox, installer was started with admin rights.
Dom Howard
January 16, 2020
I have the exact same problem, after upgrading to the latest version Sourcetree authorises itself but you are unable to move on past the Next button in the authorisation pane.
The default browser is Firefox, not Microsoft Edge
The only solution seems that as there is no fix to this year old problem is to try to downgrade to versions below 3.3.7.
Jane Zhang
January 13, 2020
I have an issue to update. I tried to update the new version of the sourcetree when I saw a yellow flag, but not successfully even I went back the previous version, the sourcetree won't work. Here are error messages from the sourcetree.log
ERROR [2020-01-13 09:48:29,629] [1] [SourceTree.UI.OnboardingManager] [Log] - Unable to submit Finished Registration Analytics
ERROR [2020-01-13 09:48:50,865] [10] [Sourcetree.Installer.Squirrel.Utils.UpdateHelper] [Log] - Failed to check for updates
System.Exception: Failed to check for updates ---> System.MissingMethodException: Method not found: 'Void Splat.IFullLogger.Info(System.String, !!0)'.
at Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__2.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.Start[TStateMachine](TStateMachine& stateMachine)
at Squirrel.UpdateManager.CheckForUpdateImpl.CheckForUpdate(String localReleaseFile, String updateUrlOrPath, Boolean ignoreDeltaUpdates, Action`1 progress, IFileDownloader urlDownloader)
at Squirrel.UpdateManager.<CheckForUpdate>d__7.MoveNext()
at Sourcetree.Installer.Squirrel.Utils.UpdateHelper.<CheckForUpdate>d__19.MoveNext()
at Sourcetree.Installer.Squirrel.Utils.UpdateHelper.<HasAvailableUpdates>d__20.MoveNext()
ERROR [2020-01-13 09:49:06,325] [13] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
at Sourcetree.Analytics.Emau.EMauSubmissionService.<SubmitBatch>d__62.MoveNext()
ERROR [2020-01-13 09:49:06,327] [13] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
ERROR [2020-01-13 09:49:06,604] [1] [SourceTree.UI.OnboardingManager] [Log] - Unable to submit Finished Registration Analytics
at SourceTree.UI.OnboardingManager.SubmitFinishedRegistrationAnalytics(Boolean onboardingResult)
ERROR [2020-01-13 09:49:06,606] [12] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
ERROR [2020-01-13 09:49:06,607] [12] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
ali kamsari
November 10, 2019
it's about your browser, change your default browser from Google Chrome to Firefox.
if still you had the same issue try using some VPN applications (ex: Hotspot shiled) .
Update : uninstall your current version of sourcetree app and download 3.1.3 version friom version history Link :
https://www.sourcetreeapp.com/download-archives
authentication will be successful after that.
Good luck.
bit Time Professionals December 10, 2019
Same problem here. I've setted EDGE as default browser and it works.
Like tawani likes this
GuxGux January 27, 2020
Worked for me after several hours of forum crawling
Deleted user March 1, 2021
Changed to Firefox and it fixed the problem. After over an hour of exhaustive research.
Like Savan Vadalia likes this
Savan Vadalia May 6, 2021
Changing default browser to firefox seem to fix the issue for me
davepery
April 10, 2019
Hi I seen error in log file.
ERROR [2019-04-10 15:59:22,576] [61] [SourceTree.Analytics.NPS.Service.NPSFeedbackService] [Log] - NPS: Couldn't record shown prompt
System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'sourcetree-nps-bridge.us-east-1.prod.public.atl-paas.net'
at SourceTree.Analytics.NPS.Transport.AuthHttpClientHandler.<SendAsync>d__2.MoveNext()
at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext()
at Refit.RequestBuilderImplementation.<>c__DisplayClass17_0.<<BuildVoidTaskFuncForMethod>b__0>d.MoveNext()
at SourceTree.Analytics.NPS.Service.NPSFeedbackService.<RecordShownPromptAsync>d__18.MoveNext()
jerrzhao.japan
April 11, 2019
I got the same problm, dont know how to solve it.
error log is different with yours, as below. Who have solving method ,plz help. thanks.
ERROR [2019-04-12 14:09:20,740] [1] [SourceTree.Analytics.Submission.Gas.GasAnalyticsSubmissionService] [Log] - Hi There!
ERROR [2019-04-12 14:10:24,900] [5] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: リモート サーバーに接続できません。 ---> System.Net.Sockets.SocketException: 接続済みの呼び出し先が一定の時間を過ぎても正しく応答しなかったため、接続できませんでした。または接続済みのホストが応答しなかったため、確立された接続は失敗しました。 52.4.35.51:443
   場所 System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
   場所 System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
   場所 System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
   --- 内部例外スタック トレースの終わり ---
   場所 System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
   場所 System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
   場所 System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   場所 System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   場所 System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext()
--- 直前に例外がスローされた場所からのスタック トレースの終わり ---
J F
December 8, 2022
December 2022
Fresh 3.4.10 install on a fresh Windows 11, and I see this behavior in Firefox and Chrome ...
Maytime
April 1, 2020
I am a newbie to sourcetree and met this problem today. I had tried nearly all the ways above. At last, I successfully installed sourcetree 3.1.3 with firefox and admin rights under win10.  Both 3.3.6 and 3.3.8 can't work no matter whatever I tried. I hope I can use the latest version ASAP.
dmikhalsky
April 13, 2020
Yje same for me
Deleted user January 31, 2020
I just changed the URL from https to http in the browser, and it worked:
https://localhost:34106/?state=authenticated&code=XXXXXX
To
http://localhost:34106/?state=authenticated&code=XXXXXX
Jane Zhang
January 24, 2020
Uninstall the new version and reinstall the older version. The issue should be solved.
ericciaparicio
January 10, 2020
same problem. Any help?
Walter H. Mcclure
January 11, 2020
Eric,
I found that an earlier version downloads and installs successfully.
Link to that download is: https://downloads.atlassian.com/software/sourcetree/windows/ga/SourceTreeSetup-2.3.5.0.exe?_ga=2.132046607.1450006588.1578741782-950746547.1578573409 which is found in these support pages: https://community.atlassian.com/t5/Sourcetree-questions/source-tree-won-t-start/qaq-p/143526
Good luck, and I hope this helps.  Not sure why ATLASSIAN is not providing any help here!
Deleted user January 12, 2020
@Walter H. Mcclure thanks that worked for me.
Like Walter H. Mcclure likes this
gitveio
November 26, 2019
I'm in windows and get the issue when install this app. But when i close the installing window and run the app with admin role, the issue is gone.
Deleted user November 26, 2019
Thanks @ali kamsari  "it's about your browser, change your default browser from Google Chrome to Firefox. " this work for me!!
Walter H. Mcclure
January 9, 2020
I am having this issue, and changing default browsers did not solve the problem.  The authenticated was successful in Firefox; however, the 'NEXT' button is still disabled in installation not allowing me to continue.
Lorenzo_Petrone January 31, 2020
I tried with Edge and it also worked, so Chrome was the problem.
dinsy
October 17, 2019
I had this today, chrome was complaining about an TLS error. I suspect chrome changes http to https if you've ever visited that domain before with HTTPS and won't let you change it to HTTP.
My fix was to copy/paste the url into FireFox and chante it to http then it worked.
I believe you can remove the entry in chrome cache somewhere but can't remember where.
Hassan NAITALI
April 22, 2019
It was a temporaty problem !!
Fetch/ Pull are working now without problem after few days.
Hassan NAITALI
April 18, 2019
Hi I have the same problem today please help !
My log:
ERROR [2019-04-18 18:07:56,253] [8] [SourceTree.Analytics.NPS.Service.NPSFeedbackService] [Log] - NPS: Couldn't record shown prompt
Ana Retamal
January 21, 2019
Hi Madhavi, welcome to the Community!
The localhost URL is correct. SourceTree runs a temporary webserver in order to support OAuth callbacks to give the auth_token. It seems like Sourcetree has been installed, it will be installed at %localappdata%/SourceTree. Can you check it is there?
If so, I guess the issue here is the 'Next' button being disabled. I can see you're on Windows, can you confirm that Internet Explorer is updated to the latest version?
Another thing you can try is to check the Sourcetree logs and tell us what you find, they can be found at
C:\Users\<username>\AppData\Local\Atlassian\SourceTree\sourcetree.log
Let us know!
Ana
davepery
April 10, 2019
Can you help me here. Please
Like Sanjini.Suresh likes this
Russel_Santos
May 21, 2020
ERROR [2020-05-22 13:59:52,802] [1] [SourceTree.Analytics.Submission.Gas.GasAnalyticsSubmissionService] [Log] - Hi There!
ERROR [2020-05-22 13:59:57,951] [20] [Sourcetree.Analytics.Emau.EMauSubmissionService] [Log] - POST MAU submission FAILED
ERROR [2020-05-22 14:00:01,378] [1] [SourceTree.UI.OnboardingManager] [Log] - Unable to submit Finished Registration Analytics
ERROR [2020-05-22 14:00:15,626] [21] [Sourcetree.Installer.Squirrel.Utils.UpdateHelper] [Log] - Failed to check for updates
ERROR [2020-05-22 14:00:45,790] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:01:50,721] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:03:23,478] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:04:28,285] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Failed to check login for user [russelsantos]
ERROR [2020-05-22 14:04:28,287] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Failed to check login for user [russelsantos]
ERROR [2020-05-22 14:06:17,189] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:07:57,855] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:08:32,287] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:08:48,819] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:09:17,507] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:12:11,968] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:14:15,901] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
ERROR [2020-05-22 14:18:41,655] [1] [SourceTree.Exceptions.RemoteHostException] [Log] - Unable to get secret
Russel_Santos
May 21, 2020
The same problem here.
