Remote branch tracking setting reset after "repo sync"
C. M.
March 7, 2019
"repo sync" seems to reset remote branch tracking settings made with Sourcetree.
After a "repo sync" I always have to do this again:
1. Right-click on a local branch (for example master)
2. Hover on "Track remote branch"
3. Select "origin/master"
This reset seems to happen because during the "repo sync", in the configuration file
\.repo\projects\..\someproject.git\config
the following bold line is changing from
[branch "master"]
remote = origin
merge = refs/heads/master
to
[branch "master"]
remote = origin
merge = master
Any idea how to avoid this?
minnsey
March 7, 2019
Hi
Can you clarify what action, buttons you are using when you refer to "repo sync" ? Thanks.
C. M.
March 12, 2019
Yes, I am talking about running repo sync in the terminal to update all projects.
