I am required to enter my password every few minutes.
This issue has started with the new version.
Maybe it's a bug?
Thanks, Guy
The problem was solved by itself.
Thanks, Guy
Hi @Guy Fingen
Did you add the auth details to your keychain when you authenticate? Did you correctly authenticate?
While authenticating click on check-box for "Save password in your keychain"
If it doesn't work for you please refer below links
https://answers.atlassian.com/questions/48102
https://answers.atlassian.com/questions/36585
