SourceTree aborts merge rather than merge with conflicts
T K September 16, 2016
In a very simple set up whenever i PULL from my branch i get 'merge aborted' if there is even a single line conflict in a remote file and my uncommitted changes.
error: Your local changes to the following files would be overwritten by merge
Please, commit your changes or stash them before you can merge.
Aborting
Sure enough, if i stash my changes or revert them i can perform the PULL just fine but i want to pull the remote file changes and have them as conflicts which i can resolve locally before committing. I can't seem to find an option for that anywhere.
SourceTree 1.9.6.1 for Windows
Diff tool and Merge tool configured: P4Merge
T K January 31, 2017
For anyone interested, it seems that SourceTree has a different approach on this.
When PULLing in Android Studio, Android Studio stashes and pulls behind the scenes (you can see the console logs) and then shows conflicts.
So, a developer has to manually perform these steps in SourceTree to achieve the same result. Stash the changes, PULL safely and then Unstash to merge the changes
Rodney
September 16, 2016
It seems you were trying to pull with uncommitted local changes.  It wants you to commit your changes first so that it can put your repo is a previous state in case you want to cancel the merge.
But this is exactly what i want...
Android studio, for example, which is also using Git is allowing for a valid PULL and then you have local conflicts to resolve. I don't see why SourceTree doesn't do that and i have to revert/stash changes...
Oddioengineer
September 23, 2019
@Rodney This is how it has worked for years! It changed recently and I too am completely annoyed. It has always been that we could have local (un-committed) changes, Pull, and Resolve all in the staging area without extra steps.
