SourceTree: not a valid source path / URL problem, missing DLLs
Christian April 4, 2016
suddenly I have Problems accessing Repositories with SourceTree. Maybe it's caused by the latest Win10 Update cause everything worked fine before.
Maybe this Update is causing the Problem? Microsoft Visual C++ 2012 Update 4 Redistributable Package (KB3119142)
First of all I wasn't able to 'Fetch' - I got some 'DLL missing' warnings.
Than I reinstalled Sourcetree and tried to Clone my Repository again. But when I past in the correct URL, I get several "Missing file" warnings again:
... ending in the Error message "This is not a valid source path / URL".
Details are initially:
Now ererytime I try it again, there are no further DLL error Messages, but the "not a valid source path" warning with this Detail Dialog:
I use Embedded Git and tried SourceTree 1.7.0 and also 1.8.3 - no difference.
It might also be an authentication Problem, but I'm not prompte for credentials anyway.
Can somebody help me out here please?
Christian
Seth
April 4, 2016
Probably not an authentication problem. If you are missing dlls for libcurl and libssh, your git installation is probably completely unable to communicate to remote servers. Try hitting the Update Embedded Git, and see if that might repair your problem.
If not, you should install your own copy of Git ("System Git" to SourceTree), and go to a git forum if it has installation problems.
Yes, indeed! With local installed Git (System Git) it's working fine again.
You saved my day - thanks a lot!!
