Sourcetree crashes with Git Flow features
Karl Beaver June 10, 2020
Sourcetree 3.3.8.3848 on Windows 10 1803.
With a Git Flow enabled repo, any time I attempt to create a feature branch via the menu (Repository > Git-flow > Start New Feature) Sourcetree immediately crashes with a BugSplat popup. Note I am using Embedded Git v 2.24.1 with git-lfs v2.9.1. The repository configuration file has the [gitflow "prefix"], [gitflow "branch"], [gitflow "path"] blocks defined. Any ideas?
DEBUG [2020-06-10 10:50:01,800] [37] [SourceTree.Utils.RepoProcess] [Log] - Elapsed time localprocess [14439320] [00:00:00.1306087]
DEBUG [2020-06-10 10:50:15,392] [39] [SourceTree.Utils.RepoProcess] [Log] - Initialize localprocess [45712546]
DEBUG [2020-06-10 10:50:15,392] [39] [SourceTree.Utils.RepoProcess] [Log] - Start localprocess [45712546] [D:\srcrepo>C:\Users\redacted\AppData\Local\Atlassian\SourceTree\git_local\cmd\git.exe flow version]
env=[git_ssh=C:\Users\redacted\AppData\Local\SourceTree\app-3.3.8\tools\putty\plink.exe,path=C:\Users\redacted\AppData\Local\Atlassian\SourceTree\git_extras;C:\Users\redacted\AppData\Local\Atlassian\SourceTree\gitflow_local\gitflow;C:\Users\redacted\AppData\Local\Atlassian\SourceTree\git_local\bin;C:\Users\redacted\AppData\Local\Atlassian\SourceTree\git_local\mingw32\bin;C:\Users\redacted\AppData\Local\Atlassian\SourceTree\git_local\mingw64\bin;C:\Users\redacted\AppData\Local\SourceTree\app-3.3.8\tools;C:\Program Files (x86)\RSA SecurID Token Common;C:\Program Files\RSA SecurID Token
[REDACTED ENV VARS]
DEBUG [2020-06-10 10:50:16,802] [39] [SourceTree.Utils.RepoProcess] [Log] - Completed localprocess [45712546] [0] [1.12.3 (AVH Edition)
DEBUG [2020-06-10 10:50:16,802] [39] [SourceTree.Utils.RepoProcess] [Log] - Elapsed time localprocess [45712546] [00:00:01.4100872]
DEBUG [2020-06-10 10:50:16,848] [39] [SourceTree.Model.Repository] [Log] - Called Checksummary for [D:\srcrepo]
ERROR [2020-06-10 10:50:16,872] [48] [SourceTree.Analytics.Crash.BugSplat.CrashAnalyticsService] [Log] - UnhandledExceptionHandler for [Sourcetree, 3.3.8.3848] called with [Name:SourceTree.exe
There are no context policies.
, System.UnhandledExceptionEventArgs]
System.NotSupportedException: This type of CollectionView does not support changes to its SourceCollection from a thread different from the Dispatcher thread.
at System.Windows.Data.CollectionView.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args)
at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
at System.Collections.ObjectModel.ObservableCollection`1.InsertItem(Int32 index, T item)
at SourceTree.ViewModel.Flow.FlowStartPanelViewModel.<InitAsync>d__42.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at SourceTree.ViewModel.Flow.FlowContainerDialogViewModel.<ChangeMode>d__24.MoveNext()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
Nicolas Clemeur
September 28, 2020
I have also the same issue but it is not happening consistently, it just crash about 1 times out of 5...
Thomas Bastiaansen
July 31, 2020
Hi, I am facing some similar issues with a curring project.
I was able to still create features by executing the command in the terminal instead of using the Sourcetree interface. Hope it helps
René Petersen
July 2, 2020
That same thing happens for me also!
